Subsonic Stops Scanning Library at the Same Position
Postby Bri » Thu Sep 06, 2018 8:29 pm
Hi Folks!
Been using the paid Subsonic for quite a while and am very happy with it.
Have recently run into an issue where media library never finishes scanning and it stops at the same position, 50197, every time I run it.
Is there anywhere I can see why it's stopping there, or at least what file it's stopping on and get subsonic to bypass it?
Bri
Re: Subsonic Stops Scanning Library at the Same Position
Postby kermit22 » Fri Sep 07, 2018 6:10 pm
Hi Bri- If you are on Windows you can check the subsonic.log file located at c:\Subsonic. Inside that log you should see entries for the MediaScannerService. If there are any errors they will be listed there.
-My Subsonic Server-
OS: Windows Server 2016
Processor: Intel Xeon E5630
Memory: 8GB
2,098 artists
4,266 albums
39,450 songs
2,606 hours
kermit22
Postby Bri » Mon Sep 10, 2018 8:31 pm
There's nothing in the subsonic.log which speaks to where in the scanning process it is. Is there any way to turn on a debug mode which increases the logging verbosity?
Bri
Users browsing this forum: No registered users and 87 guests
