BUG: Playlist not visible
Postby m3guitar » Fri Sep 14, 2018 8:51 pm
I have a high resolution screen, 3840 X 2160 pixels, and the playlist is squeezed to nothing, not a single letter is visible. Windows 10, Subsonic 6.1.3, happens with both MS Edge 42 and Firefox 62. Screenshot link https://drive.google.com/file/d/1hlYuRU ... sp=sharing
Regards
Ole Kirkeby
m3guitar
Re: BUG: Playlist not visible
Postby toolman » Fri Sep 14, 2018 10:28 pm
If you mean the list below the orange line on the bottom of the screen you might try to toggle the view with the symbol on the right (3lines and a musicnote).
toolman
Postby m3guitar » Sat Sep 15, 2018 6:31 pm
Problem solved! Thanks very much.
ole
m3guitar
Users browsing this forum: No registered users and 79 guests
