Java-10 and subsonic-6.1.3
Postby force21 » Wed Sep 19, 2018 11:13 am
Problem Description: I can't get subsonic-6.1.3 to start with Java-10.
Troubleshooting Steps: Start subsonic with OpenJDK/OpenJRE 10
Playback Application and version: -
Subsonic Version: 6.1.3
Server Version: -
Hardware Platform: Gentoo Linux
Java Memory Limit: -Xmx150m
Problem Filename: -
Output from ffmpeg -i:
ffmpeg version 3.4.4 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7.3.0 (Gentoo 7.3.0-r3 p1.4)
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --docdir=/usr/share/doc/ffmpeg-3.4.4/html --mandir=/usr/share/man --enable-shared --cc=gcc --cxx=g++ --ar=x86_64-pc-linux-gnu-ar --optflags='-march=core-avx2 -mtune=native -O2 -pipe -fomit-frame-pointer' --disable-static --enable-avfilter --enable-avresample --disable-stripping --enable-nonfree --disable-indev=v4l2 --disable-outdev=v4l2 --disable-indev=oss --disable-indev=jack --disable-outdev=oss --disable-outdev=sdl --enable-nonfree --enable-bzlib --enable-runtime-cpudetect --disable-debug --disable-gcrypt --disable-gnutls --disable-gmp --enable-gpl --enable-hardcoded-tables --enable-iconv --enable-lzma --enable-network --enable-opencl --enable-openssl --enable-postproc --disable-libsmbclient --disable-ffplay --disable-sdl2 --enable-vaapi --enable-vdpau --enable-xlib --enable-libxcb --enable-libxcb-shm --enable-libxcb-xfixes --enable-zlib --disable-libcdio --disable-libiec61883 --disable-libdc1394 --disable-libcaca --disable-openal --enable-opengl --disable-libv4l2 --disable-libpulse --disable-libdrm --disable-libopencore-amrwb --disable-libopencore-amrnb --enable-libfdk-aac --enable-libopenjpeg --disable-libbluray --disable-libcelt --disable-libgme --disable-libgsm --disable-mmal --disable-libmodplug --enable-libopus --disable-libilbc --disable-librtmp --disable-libssh --disable-libspeex --enable-librsvg --enable-libvorbis --enable-libvpx --disable-libzvbi --disable-appkit --disable-libbs2b --disable-chromaprint --disable-libflite --enable-frei0r --disable-libfribidi --enable-fontconfig --disable-ladspa --disable-libass --enable-libfreetype --disable-librubberband --disable-libzmq --disable-libzimg --disable-libsoxr --enable-pthreads --disable-libvo-amrwbenc --enable-libmp3lame --disable-libkvazaar --disable-nvenc --disable-libopenh264 --disable-libsnappy --enable-libtheora --disable-libtwolame --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --disable-armv5te --disable-armv6 --disable-armv6t2 --disable-neon --disable-vfp --disable-vfpv3 --disable-armv8 --disable-mipsdsp --disable-mipsdspr2 --disable-mipsfpu --disable-altivec --disable-amd3dnow --disable-amd3dnowext --disable-avx2 --disable-fma3 --disable-fma4 --disable-xop --cpu=core-avx2 --disable-doc --disable-htmlpages --enable-manpages
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
Missing argument for option 'i'.
Error splitting the argument list: Invalid argument
Last ten log file lines:
javax.xml.bind.JAXBException: Package javax.xml.datatype with JAXB class javax.xml.datatype.XMLGregorianCalendar defined in a module java.xml must be open to at least java.xml.bind module.
Here is the full log:
2814 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@630cb4a4: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,videoConversionDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,lastFmService,bookmarkService,videoConversionService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,loginFailureLogger,net.sourceforge.subsonic.security.SubsonicApplicationEventListener#0,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
2817 [main] WARN org.springframework.beans.factory.support.DisposableBeanAdapter - Invocation of destroy method 'shutdown' failed on bean with name 'cxf': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'ajaxTagServiceSecure': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2817 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sonosEndpoint': Invocation of init method failed; nested exception is javax.xml.ws.WebServiceException: org.apache.cxf.service.factory.ServiceConstructionException
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1338)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
   at java.base/java.security.AccessController.doPrivileged(Native Method)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
   at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
   at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:488)
Caused by: javax.xml.ws.WebServiceException: org.apache.cxf.service.factory.ServiceConstructionException
   at org.apache.cxf.jaxws.EndpointImpl.doPublish(EndpointImpl.java:350)
   at org.apache.cxf.jaxws.EndpointImpl.publish(EndpointImpl.java:239)
   at org.apache.cxf.jaxws.EndpointImpl.publish(EndpointImpl.java:509)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.base/java.lang.reflect.Method.invoke(Method.java:564)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
   ... 50 more
Caused by: org.apache.cxf.service.factory.ServiceConstructionException
   at org.apache.cxf.jaxb.JAXBDataBinding.initialize(JAXBDataBinding.java:292)
   at org.apache.cxf.service.factory.AbstractServiceFactoryBean.initializeDataBindings(AbstractServiceFactoryBean.java:86)
   at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.buildServiceFromClass(ReflectionServiceFactoryBean.java:438)
   at org.apache.cxf.jaxws.support.JaxWsServiceFactoryBean.buildServiceFromClass(JaxWsServiceFactoryBean.java:682)
   at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.initializeServiceModel(ReflectionServiceFactoryBean.java:501)
   at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.create(ReflectionServiceFactoryBean.java:241)
   at org.apache.cxf.jaxws.support.JaxWsServiceFactoryBean.create(JaxWsServiceFactoryBean.java:202)
   at org.apache.cxf.frontend.AbstractWSDLBasedEndpointFactory.createEndpoint(AbstractWSDLBasedEndpointFactory.java:101)
   at org.apache.cxf.frontend.ServerFactoryBean.create(ServerFactoryBean.java:157)
   at org.apache.cxf.jaxws.JaxWsServerFactoryBean.create(JaxWsServerFactoryBean.java:202)
   at org.apache.cxf.jaxws.EndpointImpl.getServer(EndpointImpl.java:433)
   at org.apache.cxf.jaxws.EndpointImpl.doPublish(EndpointImpl.java:322)
   ... 59 more
Caused by: javax.xml.bind.JAXBException: Package javax.xml.datatype with JAXB class javax.xml.datatype.XMLGregorianCalendar defined in a module java.xml must be open to at least java.xml.bind module.
   at java.xml.bind@10.0.2/javax.xml.bind.ModuleUtil.delegateAddOpensToImplModule(ModuleUtil.java:145)
   at java.xml.bind@10.0.2/javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:278)
   at java.xml.bind@10.0.2/javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:271)
   at java.xml.bind@10.0.2/javax.xml.bind.ContextFinder.find(ContextFinder.java:394)
   at java.xml.bind@10.0.2/javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:706)
   at org.apache.cxf.jaxb.JAXBContextCache.createContext(JAXBContextCache.java:258)
   at org.apache.cxf.jaxb.JAXBContextCache.getCachedContextAndSchemas(JAXBContextCache.java:167)
   at org.apache.cxf.jaxb.JAXBDataBinding.createJAXBContextAndSchemas(JAXBDataBinding.java:418)
   at org.apache.cxf.jaxb.JAXBDataBinding.initialize(JAXBDataBinding.java:290)
   ... 70 more
   ... 50 more
   ... 59 more
   ... 70 more
2821 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sonosEndpoint': Invocation of init method failed; nested exception is javax.xml.ws.WebServiceException: org.apache.cxf.service.factory.ServiceConstructionException:
2834 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
[2.968s][info][gc] GC(11) Pause Remark 45M->45M(150M) 6.944ms
2860 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
2873 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
[2.993s][info][gc] GC(11) Pause Cleanup 46M->46M(150M) 0.182ms
[2.993s][info][gc] GC(11) Concurrent Cycle 78.955ms
2930 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.0.1:9412](local),objID:[0:0:0, 0]]]]
force21
Users browsing this forum: No registered users and 88 guests
