Can't load parts of the interface, Subsonic can't find music
Postby bertrand » Wed Sep 19, 2018 1:55 pm
I'm at work and not at home where the server is located so I don't know if I can do much from here...
SO here's the problem: the login page looks fine, but when I log in as user I get an exception instead of the left menu panel.
If I try to load the "Index" I get the same error, which I've pasted in the code block below.
I don't see this exception at all when login in as admin. However, it appears as though i have no music at all.
Any attempt to rescan any folder immediately fails.
The giant block seemed to indicate memory issues so i tried scanning a smaller folder with only a dozen media files in it instead of the usual one and that didn't change anything.
What on earth is going on?? I've been using this for over a year never encountered something like this.
Here are the latest bunch of log entries:
[9/19/18 7:46:53 AM EDT]    INFO   NetworkService   Successfully forwarding port 4040.
[9/19/18 8:00:12 AM EDT]    INFO   MediaScannerService   Starting to scan media library.
[9/19/18 8:00:15 AM EDT]    ERROR   MediaScannerService   Failed to scan media library.
[9/19/18 8:00:15 AM EDT]    INFO   PlaylistService   Starting playlist import.
[9/19/18 8:00:15 AM EDT]    INFO   PlaylistService   Completed playlist import.
[9/19/18 8:19:57 AM EDT]    INFO   VersionService   Resolved latest Subsonic final version to: 6.1.3
[9/19/18 8:19:57 AM EDT]    INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
[9/19/18 8:22:09 AM EDT]    INFO   NetworkService   Successfully forwarding port 4040.
[9/19/18 9:24:18 AM EDT]    INFO   NetworkService   Successfully forwarding port 4040.
[9/19/18 9:33:15 AM EDT]    INFO   PlayerDao   Created player 32.
[9/19/18 9:33:55 AM EDT]    INFO   MediaScannerService   Starting to scan media library.
[9/19/18 9:33:57 AM EDT]    ERROR   MediaScannerService   Failed to scan media library.
[9/19/18 9:33:57 AM EDT]    INFO   PlaylistService   Starting playlist import.
[9/19/18 9:33:57 AM EDT]    INFO   PlaylistService   Completed playlist import.
[9/19/18 9:36:54 AM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Sep 20 08:00:00 EDT 2018
[9/19/18 9:36:57 AM EDT]    INFO   MediaScannerService   Starting to scan media library.
[9/19/18 9:36:59 AM EDT]    ERROR   MediaScannerService   Failed to scan media library.
[9/19/18 9:36:59 AM EDT]    INFO   PlaylistService   Starting playlist import.
[9/19/18 9:36:59 AM EDT]    INFO   PlaylistService   Completed playlist import.
[9/19/18 9:38:46 AM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Sep 20 08:00:00 EDT 2018
[9/19/18 9:38:53 AM EDT]    INFO   MediaScannerService   Starting to scan media library.
[9/19/18 9:38:55 AM EDT]    ERROR   MediaScannerService   Failed to scan media library.
[9/19/18 9:38:55 AM EDT]    INFO   PlaylistService   Starting playlist import.
[9/19/18 9:38:55 AM EDT]    INFO   PlaylistService   Completed playlist import.
[9/19/18 9:43:19 AM EDT]    INFO   MusicFolderDao   Deleted music folder with ID 0
[9/19/18 9:43:19 AM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Sep 20 08:00:00 EDT 2018
[9/19/18 9:43:23 AM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Sep 20 08:00:00 EDT 2018
[9/19/18 9:43:25 AM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Thu Sep 20 08:00:00 EDT 2018
[9/19/18 9:43:33 AM EDT]    INFO   MediaScannerService   Starting to scan media library.
[9/19/18 9:43:33 AM EDT]    INFO   MediaScannerService   Scanned media library with 1 entries.
[9/19/18 9:43:33 AM EDT]    INFO   MediaScannerService   Marking non-present files.
[9/19/18 9:43:34 AM EDT]    ERROR   MediaScannerService   Failed to scan media library.
[9/19/18 9:43:34 AM EDT]    INFO   PlaylistService   Starting playlist import.
[9/19/18 9:43:34 AM EDT]    INFO   PlaylistService   Completed playlist import.
And here's that huge error message:
Error
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version   Oracle Corporation 1.8.0_31
Operating system   Windows 8 6.2
Server   jetty-6.1.x
Memory   Used 59 of 145 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
   at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:68)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:187)
   at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:158)
   at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
   at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
   at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:45)
Caused by: java.sql.SQLException: out of memory
   ... 64 more
bertrand
Re: Can't load parts of the interface, Subsonic can't find m
Postby bertrand » Wed Sep 19, 2018 8:04 pm
I managed to fix the exception by deleting and recreating my media folders from the Subsonic admin panel, however now it seems to get stuck during scanning. "Index" only shows a small section of files (all between K and L) and hasn't changed for several hours. The right panel shows "Scanning files: 1", and the log hasn't turned up any "Error when parsing tags" in hours which makes me think it's not actually scanning anything anymore and is somehow stuck. Resetting the media folders at this stage seems doesn't seem to fix the problem, I'm back where I started once I set them back up. Not sure where to go from here, is there a way to reboot the Subsonic server remotely?
Edit: It actually did hit a "Error when parsing tags" a few minutes ago just now so I guess it is still scanning, but very slowly like it will take 24 hours at this rate... which is much slower than normal.
bertrand
Postby bertrand » Wed Sep 19, 2018 10:07 pm
I'm not sure why things are getting stuck but I guess the music database is somehow corrupt. I just removed ALL media folders, and ran "Clean-up database", and the "subsonic.data" file is still over 250MB. Shouldn't it be much smaller now that there's no media? What's taking up all that space?
How do I get it to rebuild?
bertrand
Postby toolman » Wed Sep 19, 2018 10:10 pm
Seems to me that your Java installation somehow got corrupt.
I would uninstall Java completely and than install the latest version which would now be Java 8 Update 181.
The database of my subsonic server never was smaller than 250 mb and didn't grow over the years while I now have a mediacollection of 1.5 TB
toolman
Postby bertrand » Mon Sep 24, 2018 6:36 pm
I deleted the large "subsonic.data", re-scanned everything (took way longer than normal), but now all seems to be working.
bertrand
Postby acroyear » Mon Sep 24, 2018 9:12 pm
the first scan on a clean DB is always the longest because every file has to be added into the DB (including artist, album, genre, etc).
after that, the scanner looks only for folders that have changed to see what files inside have changed, thus most of the files don't need examining.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Users browsing this forum: No registered users and 88 guests
