Cannot connect to Subsonic even on LAN
Postby aldburg » Wed Sep 26, 2018 1:27 am
I moved to a new state and I noticed after connecting my router and PC that I cannot connect to my subsonic server even when I'm on my laptop and connected to my lan. My PC acts as my server and I can connect through it using the address, http://localhost:4040/ but besides my PC, nothing can connect to the server anymore. Any ideas?
aldburg
Re: Cannot connect to Subsonic even on LAN
Postby jgraythe4th » Wed Sep 26, 2018 1:43 am
Sounds like you need to setup the port on your new router. Once you do that everything will connect again. Make sure you can also connect to your Subsonic server through your laptop from the local IP address of your subsonic server, example: http://192.168.0.2:4040
jgraythe4th
Postby aldburg » Tue Oct 02, 2018 2:38 am
Status on the subsonic page says:
Status: Successfully forwarding port 4040.
I also manually port forwarded 4040 and it still isn't working.
aldburg
Postby aldburg » Tue Oct 02, 2018 3:10 am
I was able to get it to work. I changed my Port Forwarding address to a different port and set subsonic to that port. I also found another issue is that I was connected to a VPN and subsonic was trying to redirect it to that IPv4 address when it should have been to my ethernet adapter. :evil: What a headache with VPN
aldburg
Users browsing this forum: No registered users and 74 guests
