SSL & Ubuntu install
Postby Bristow » Wed May 06, 2009 6:28 pm
Hello ;)
I've installed my Subsonic on my Ubuntu computer with standalone installation, and if i've well understood, i've a Jetty server.
Now, i'd like to use SSL protection on it.
Do you have a tutorial for this ? Is is difficult to do ? Is it possible ?
Thank you again for this software :P
Cedric
Bristow
Postby jigsaw » Wed May 06, 2009 7:26 pm
Hi Bristow
SSL streaming works, but there are some issues regarding the internal redirect while using SSL. It is fixed in the next release 3.7 ( more details regarding the problems and solution here: http://forum.subsonic.org/forum/viewtopic.php?t=1301)
For info on how to setup SSL with Jetty you could look at this link: http://docs.codehaus.org/display/JETTY/ ... figure+SSL
jigsaw
Postby Bristow » Wed May 06, 2009 7:32 pm
Thanks for links jigsaw
Is there a date of release for Subsonic 3.7 ?
And, will it be difficult to upgrade my version 3.6 ?
Bristow
Postby jigsaw » Wed May 06, 2009 7:40 pm
I read Sindre mentioning that we might see a beta release shortly. ( the exact term I guess was in a week or two, and that was two weeks ago :) )
Upgrading is a piece of cake. Just drop the new tar.gz in the same place as you did the first time, extract it and restart subsonic.
PS: If you have done any modifications to the subsonic.sh or something like that you might want to make a separate copy of that and do the same modifications to the new one.
If it's a vanilla installation you do not have to do anything :)
All settings, statistics and so forth are stored in the database which persists an upgrade.
jigsaw
Postby sindre_mehus » Thu May 07, 2009 9:00 pm
jigsaw wrote:I read Sindre mentioning that we might see a beta release shortly. ( the exact term I guess was in a week or two, and that was two weeks ago :) )
Have you noticed the beautiful spring weather in Norway lately 8)
Also, I'm building a new "terrasse"...
Cheers!
Postby Bristow » Wed May 13, 2009 7:03 pm
jigsaw wrote:Upgrading is a piece of cake. Just drop the new tar.gz in the same place as you did the first time, extract it and restart subsonic.
Wonderful... i'll download and install it !
Bristow
Postby Bristow » Thu May 14, 2009 3:59 pm
Ok for upgrade, a piece of cake :lol:
Now, i'd like to use SSL protocol but i's a little bit difficult, i used tutorial http://docs.codehaus.org/display/JETTY/ ... figure+SSL but it's too much hard to understand for me.
There is too much cases, i'd like to have just commands that i need...
Is there a another little tutorial ? Thanks for your help !
Bristow
Postby Bristow » Sun May 24, 2009 8:04 pm
Hello guys !
I need a little help to configure Jetty... where is the XML file specified here : http://docs.codehaus.org/display/JETTY/ ... eSSL-step4 ?
Thanks a lot !
Bristow
