Albums are listed but no songs!?
Postby mattyc » Fri May 08, 2009 12:34 am
Hi there,
I have just setup subsonic as well its awesome!
But i am having a problem. I have selected the dir which my music is in /home/users/Music and subsonic is now listing all the albums that I have.
When I click on the album there appears to be nothing inside it (even though there is in the folder)
I have lame setup also.
Can anyone tell me what Im doing wrong? Or does it take a while for the songs to propegate and become available.
I have updated the index search as well.
Thanks, Matt
P.S. this is what i get top left
0 artists
0 albums
0 songs
0 B (~ 0 hours)
mattyc
Postby jonathanroz » Fri May 08, 2009 1:25 am
My first guess would be that your file type is not listed in Subsonic.
Settings --> General --> Music Mask.
Mine shows: .mp3 .ogg .aac .flac .m4a .wav .wma
If you have files with a different extension they will not be shown. If you change it you might need to reindex Settings --> Search --> Update Search Index
My Second guess is that the indexing isnt completed.
My 3rd guess would be that it is a permissions issue. If you are using Ubuntu you can do Sudo Nautilus in a terminal session and set the permissions by right clicking your music folder. Or any linux based system allows you to use chmod see http://catcode.com/teachmod/
jonathanroz
