Two Issues I Am Experiencing
Postby hoojoe666@gmail.com » Tue Dec 18, 2018 11:32 pm
V 6.1.5 build 759abe
Running on Windows 10 VM
1. On the home section, RANDOM, STARRED, and TOP RATED all show blank. No music is shown since the most recent update.
2. After adding a new artist with 3 songs, if I go to index, then click the newly added artist, I get the following error:
Exception
org.springframework.dao.DataIntegrityViolationException
Message
PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; Violation of unique constraint $$: duplicate value(s) for column(s) $$: SYS_PK_128 in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: Violation of unique constraint $$: duplicate value(s) for column(s) $$: SYS_PK_128 in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Java version
Oracle Corporation 1.8.0_152
Operating system
Windows 10 10.0
Server
jetty-6.1.x
Memory
Used 64 of 128 MB
Stack trace
org.springframework.dao.DataIntegrityViolationException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; Violation of unique constraint $$: duplicate value(s) for column(s) $$: SYS_PK_128 in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: Violation of unique constraint $$: duplicate value(s) for column(s) $$: SYS_PK_128 in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:100)
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:68)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:165)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:101)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:64)
at net.sourceforge.subsonic.service.MediaFileService.findCoverArt(MediaFileService.java:599)
at net.sourceforge.subsonic.service.MediaFileService.createMediaFile(MediaFileService.java:513)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:118)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:145)
at net.sourceforge.subsonic.controller.MainController.getMediaFiles(MainController.java:167)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:52)
Caused by: java.sql.SQLException: Violation of unique constraint $$: duplicate value(s) for column(s) $$: SYS_PK_128 in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
... 66 more
Any help or suggestions would be greatly appreciated!
hoojoe666@gmail.com
