will it work with echo dot
Postby daveanders » Sat Dec 22, 2018 10:21 pm
Greetings
I am trying to get an echo dot to play music contained in a folder on my kindle. If I set up subsonic on the kindle and set up spotify will I be able to tell 'alexa' to play tracks from the folder on the kindle?
thanks for any help
Dave
daveanders
Re: will it work with echo dot
Postby G8DHE » Sun Dec 23, 2018 9:25 am
A search gives the answer as NOT EASY or likely; viewtopic.php?p=74784#p74784
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Users browsing this forum: Bing [Bot] and 74 guests
