Subsonic stream to WordPress
Postby sania-owner » Fri Jan 04, 2019 8:59 am
Hello
I have installed subsonik. Everything works perfectly. Also created a site on Wordpress. Is it possible to integrate music from subsonics to the site? Not in the form of links, and for example using a plugin if there is one. I found only the opportunity to share music, it turns out a string type https://my_ip/share/WDFERVB. If anyone encountered or may know please tell me.
Thank you in advance
sania-owner
Re: Subsonic stream to WordPress
Postby acroyear » Fri Jan 04, 2019 10:25 pm
The string can be used for a link, or as the SRC for an <iframe> tag. if you do the iframe thing, you'll need to likely set the width and height of it explicitly to have it render correctly.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Users browsing this forum: Bing [Bot] and 80 guests
