Error
Error
Postby xaphoo » Wed Jan 09, 2019 6:45 pm
I got this error, which takes up the left sidebar of the Subsonic page (the main window, and the top buttons, are fine):
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
Java version Oracle Corporation 1.8.0_152
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 65 of 108 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:68)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:187)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:158)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:45)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]
... 64 more
Any idea how I can fix this? I've tried installing a new version of Java and also reinstalling Subsonic over the previous installation. I am reluctant to uninstall anything because I don't want to redo my settings.
xaphoo
Re: Error
Postby ElliotWilson » Sat Jan 19, 2019 3:22 am
I'm getting the same exact error! (Mine says I've used 25 MB out of 101 MB, but they're otherwise identical.)
Reinstalling Subsonic and updating Java didn't work. Any help would be appreciated!
ElliotWilson
Re: Error
Postby pinkmoon » Sun May 19, 2019 8:37 am
Same here. Anyone found a fix for this yet?
Thanks.
pinkmoon
Users browsing this forum: No registered users and 81 guests
