http:*.subsonic.org redirect broken? [SOLVED]
Postby wally.nl » Mon Feb 04, 2019 3:22 pm
It seems like the redirect for my registered subsonic.org is no longer working. It sees I'm a premium user and the status says "[my_setting].subsonic.org responded successfully." but it doesn't work and complains about a 172.17.0.1 taking too long to respond (not my IP). Subsonic works fine on my lan and connecting to it from the outside is working fine as well so the port redirect etc is working as it should, it's seems just the subsonic.org redirect that is not working for me.
Can others confirm the same issue? Although perhaps I'm the only one still using this feature :)
[5-2] Seems the redirect issue has been resolved, just checked this morning and all is well.
6,695 artists - 14,412 albums - 170,363 songs - 1462.83 GB - 12,978 hours
wally.nl
Re: http:*.subsonic.org redirect broken?
Postby G8DHE » Mon Feb 04, 2019 4:24 pm
The address range being reported is a private address range, that shouldn't be visible to the Internet as such!
https://en.wikipedia.org/wiki/Private_network
Sounds like the redirect isn't playing nicely, might be worth leaving the machine up for a while to make sure your current ip address has been picked up correctly.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby wally.nl » Mon Feb 04, 2019 8:02 pm
I know it's a private range but since I'm not using that 172.16.0.0/12 range anywhere in my home network (forgot to mention that) I'm guessing the problem resides on the subsonic.org end and I was mainly curious if others had the same issue. My nas running subsonic is online 24/7 and I already retried registering the name a few times (no errors, only 'responded successfully ' messages).
wally.nl
Users browsing this forum: No registered users and 86 guests
