503 Error | Unclear Why
Postby droviin » Sat Feb 23, 2019 4:25 am
For the life of me, I cannot figure this one out. I'm running an Ubuntu server 16.04 LTR running 3 programs: mumble, Minecraft, and Subsonic 1.6.5. For the latter two, I'm using OpenJDE Java 8.
This is a fresh install and subsonic has constant database issues. I believe it's a database issue because when I delete /var/subsonic/db I can access the web interface (503 error).
I have music in /var/music. The subsonic user is the owner of the folder.
Whenever I try to rebuild the database, the whole machine locks up. I thought at first it was just Subsonic, but I was on mumble and it booted me for failure to respond to TCP pings.
For a hot minute, I had it working and rebuilt the entire database, but then suddenly the whole series of events happened again. I have no idea what's going on.
I've followed all the 503 error recommendations and nothing appears to make a difference.
Edit: The 503 error goes away if I give Subsonic 1G of space. However, there is still no playback on any file.
droviin
Re: 503 Error | Unclear Why
Postby droviin » Sat Mar 02, 2019 7:48 pm
I figured it out. The database was causing the error. Basically, it's large enough that running a second scan (presumably without cleaning the database) corrupts the database and needs a reset. However, just deleting the db folder isn't sufficient; that's what's stumping me at this point.
If there was a way to automate a database cleanup, I think the problem would go away; but that's beyond my skills.
droviin
Postby droviin » Sun Mar 17, 2019 11:43 pm
It crashed again, I discovered it after not using the service in a bit. The following is the log if anyone can help:
[2019-03-09 04:02:50,570] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
        at net.sourceforge.subsonic.dao.schema.hsql.Schema25.execute(Schema25.java:21)
        at net.sourceforge.subsonic.dao.DaoHelper.init(DaoHelper.java:27)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
        at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
        at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
        at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
Caused by: java.sql.SQLException: User not found: SA
droviin
Users browsing this forum: No registered users and 81 guests
