Subsonic server disconnects and requires modem/router reset
Postby lveill1 » Thu Mar 21, 2019 7:23 pm
I've been using Subsonic for years without much issue. However, the past few weeks I find that the subsonic server icon turns red every day. Restarting my modem and router solves the issue, but I didn't change anything so I'm wondering what's causing the problem. Any suggestions or advice regarding how to troubleshoot the issue will be much appreciated.
lveill1
Re: Subsonic server disconnects and requires modem/router re
Postby LRanger » Sat Mar 23, 2019 2:23 am
On the router have you portforwarded the port you're using (4040 maybe) to the IP address of the PC running subsonic? If you haven't, you could try that.
LRanger
Postby lveill1 » Sat Mar 23, 2019 8:25 pm
I've been using the "automatically configure your router to allow incoming connections to Subsonic (using UPnP or NAT-PMP port forwarding)." setting. Works completely fine, but lately it requires a restart every day. Any ideas regarding the cause of this? I haven't updated my router/modem firmware or subsonic software since the last update in December.
lveill1
Postby 3Dscrewer » Thu Mar 28, 2019 11:38 am
A Girl friend of me has had something like that with an AVM Router and a wireless printer. There was a problem with the memory for the settings. Even reset to factory defaults didn't clear the settings ....
Try to change the router, maybe a friend has one in the basement.
3Dscrewer
Postby lveill1 » Sat Mar 30, 2019 3:31 pm
If it's any additional help for troubleshooting I've realized restarting the computer also works, so I don't think it's a case of a broken router.
lveill1
Postby 3Dscrewer » Tue Apr 09, 2019 8:59 am
Then it might be the firewall, what OS you are using?
3Dscrewer
Users browsing this forum: No registered users and 110 guests
