Subsonic creates m3u with local ip.
Postby bibelen » Mon Apr 01, 2019 3:05 pm
Problem Description:
When using "External player with playlist"-option, Subsonic creates a M3U with local ip-adress. This happens when I'm using Subsonic from my browser with my IP-adress: http://92.221.XXX.XX:4040/index.view For some reason, Subsonic will use my remote machine's local IP for my M3U's. Line from M3U:
http://192.168.86.50:4040/stream?player ... uffix=.m4a
Troubleshooting Steps:
Find&replace ip-adress manually. Works, but is tedious work.
Playback Application and version:
FOOBAR 2000, but not really relevant.
Subsonic Version:
6.1.5 (build 759abe) – December 1, 2018
Server Version:
jetty-6.1.x, java 1.8.0_152, HSQLDB, Windows 10 (70.3 MB / 103.5 MB)
Hardware Platform:
Windows 10
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines:
[4/1/19 12:18:06 PM CEST]   INFO   PodcastService   Completed scheduled Podcast refresh.
[4/1/19 12:43:17 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/1/19 1:43:17 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/1/19 2:43:18 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/1/19 3:43:18 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/1/19 4:43:18 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
[4/1/19 5:31:59 PM CEST]   INFO   VersionService   Resolved local Subsonic version to: 6.1.5
[4/1/19 5:32:00 PM CEST]   INFO   PlayerDao   Created player 13.
[4/1/19 5:32:00 PM CEST]   INFO   VersionService   Resolved latest Subsonic final version to: 6.1.5
[4/1/19 5:32:00 PM CEST]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
[4/1/19 5:37:27 PM CEST]   INFO   PlayerDao   Created player 14.
[4/1/19 5:41:38 PM CEST]   INFO   PlayerDao   Created player 15.
[4/1/19 5:43:19 PM CEST]   INFO   NetworkService   Successfully forwarding port 4040.
bibelen
Re: Subsonic creates m3u with local ip.
Postby Jägs » Thu Apr 04, 2019 2:46 am
Under Settings --> Network, what do you have anything set under "Access your server over the Internet using an easy-to-remember address?"
Jägs
Postby bibelen » Thu Apr 04, 2019 11:34 am
No. I was trying to do this without a premium subscription. Maybe it can't be done without paying.
bibelen
Postby 3Dscrewer » Tue Apr 09, 2019 8:57 am
I have just created a playlist, there is the (my) URL in front where you are having the local IP. I'm using my own URL instead the subsonic URL. There are a lots of free services you can use, (but it might be that you need the premium version) but on the other hand ... 1$ p.M. is not to much.
Another way, there a couple of subsonic clones at github, search and try ....
3Dscrewer
Users browsing this forum: No registered users and 101 guests
