Favorites Lost
Favorites Lost
Postby Immanuel » Mon Apr 01, 2019 7:29 pm
Hi there,
I am using subsonic for a while and therefore have many favorites.
But unfortunately, all are lost, because i moved the music location to another folder.
How can that happen?!
Is there a solution?
I would be too bad if all is lost.
Any idea how to recover?
Thank you :)
Immanuel
Re: Favorites Lost
Postby Jägs » Thu Apr 04, 2019 2:42 am
First option (the easy way): move the music back. I may be wrong--and others can correct me--but unless you do a clean database operation, the favorites should still be there, so moving the music back to the original path would bring them back.
Second option (the hard way): go into the DB (http://your url/db.view) and update the paths manually. You MUST very careful when you do this, or you risk screwing up Subsonic.
Here's the DB schema:
https://www.reddit.com/r/subsonic/comme ... le_schema/
So, you'd want to do something like this:
update MEDIA_FILE set PATH = replace (PATH, '/old/path', '/new/path')
Not sure I have the syntax exact, as I do not work much in HSQL, but that should get you started.
Jägs
Re: Favorites Lost
Postby Immanuel » Thu Apr 04, 2019 5:35 pm
Thank you for the help :)
ok, I have never done anything with HSQL.
Should it look like this?: update MEDIA_FILE set PATH = replace (PATH, '/E:\Musik', 'E:\Daten\Musik')
Unfortunately i have done a complete rescan because i have not known that it causes this failure.
Immanuel
Users browsing this forum: No registered users and 81 guests
