Subsonic crashed, DB rejecting all new connections
Postby nasko » Sat May 04, 2019 1:04 pm
Ubuntu18, Subsonic 6.5
Have been Using Subsonic Premium for years. Suddenly 1week ago it crashed (couldn't even login). Restarted the server and few days later the same thing happen.
More digging shows that DB-log full has tons of connect/disconnect messages:
sudo tail /var/subsonic/db/subsonic.log
CONNECT USER SA
DISCONNECT
/*C879996*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C879997*/SET SCHEMA PUBLIC
CONNECT USER SA
DISCONNECT
/*C879998*/SET SCHEMA PUBLIC
Apparently for some reason the Database is rejecting all new connections.
Help appreciated.
nasko
---------- What I get when trying to login ------------
Error
Exception org.springframework.jdbc.CannotGetJdbcConnectionException
Message Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/subsonic/db/subsonic.log
Java version Oracle Corporation 1.8.0_191
Operating system Linux 4.15.0-47-generic
Server jetty-6.1.x
Memory Used 76 of 128 MB
Stack trace org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: /var/subsonic/db/subsonic.log
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:59)
at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:93)
at net.sourceforge.subsonic.controller.MultiController.login(MultiController.java:65)
at sun.reflect.GeneratedMethodAccessor60.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
Caused by: java.sql.SQLException: File input/output error: /var/subsonic/db/subsonic.log
at org.hsqldb.jdbc.jdbcConnection.(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
... 68 more
nasko
Re: Subsonic crashed, DB rejecting all new connections
Postby nasko » Sat May 04, 2019 6:52 pm
Turned out - I have ran out of disk space :) Pretty sure that was it !
nasko
Postby pinkmoon » Sun May 19, 2019 8:40 am
I had a similar error (org.springframework.dao.TransientDataAccessResourceException) and had run out of disk space, only that's no longer an issue, I'#ve rtestarted the PC and still have no side bar or music showing in the main panel.
Also, can't see any fixes to this on siumilar posts - any ideas anyone??
Thanks.
pinkmoon
Users browsing this forum: No registered users and 99 guests
