MediaScannerService Failed to scan media library.
Postby mroell » Tue May 07, 2019 10:21 pm
Subsonic is running on a Windows 10 machine with the standard install defaults. All of my playlists are empty, however they show the correct number of songs. When looking at "All" only a few albums/songs are available. I tried to run a "Scan media folders" but it fails with the following:
[5/7/19 2:06:49 PM PDT] INFO BootstrapVerificationFilter Servlet container: jetty-6.1.x
[5/7/19 2:13:13 PM PDT] INFO PlayerDao Created player 19.
[5/7/19 2:13:13 PM PDT] INFO VersionService Resolved latest Subsonic final version to: 6.1.5
[5/7/19 2:13:13 PM PDT] INFO VersionService Resolved latest Subsonic beta version to: 6.1.beta2
[5/7/19 2:14:09 PM PDT] INFO MediaScannerService Starting to scan media library.
[5/7/19 2:14:10 PM PDT] ERROR MediaScannerService Failed to scan media library.
[5/7/19 2:14:10 PM PDT] INFO PlaylistService Starting playlist import.
[5/7/19 2:14:10 PM PDT] INFO PlaylistService Completed playlist import.
[5/7/19 2:35:45 PM PDT] INFO MediaScannerService Starting to scan media library.
[5/7/19 2:35:46 PM PDT] ERROR MediaScannerService Failed to scan media library.
[5/7/19 2:35:46 PM PDT] INFO PlaylistService Starting playlist import.
[5/7/19 2:35:46 PM PDT] INFO PlaylistService Completed playlist import.
[5/7/19 2:35:50 PM PDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Wed May 08 03:00:00 PDT 2019
[5/7/19 3:02:36 PM PDT] INFO NetworkService Successfully forwarding port 4040.
At this point I'm not sure the best way to resolve the issue.
Matt
mroell
Re: MediaScannerService Failed to scan media library.
Postby 3Dscrewer » Fri May 10, 2019 7:01 am
Antivirus?
On the other Hand, on my System I have 250.000 Music Titles and a lots of Videos. A scan lasts only a couple of minutes. Export your playlists (in my System I can't find them) and do a new setup, if you don't have to much user.
I don't know why, but it seems that the Linux logfiles are much more informative.
3Dscrewer
Postby mroell » Fri May 10, 2019 5:51 pm
I just preformed a new install, I remove all Subsonic files/folders (I don't care about the playlists). Yeah I know that Linux has more logs then windows does, I found very little information in the Windows Event Viewer. Normally I use Linux, however the RAID card that I'm using doesn't have great support for Linux.
mroell
Postby 3Dscrewer » Sat May 11, 2019 8:55 am
If you are having W10Pro you can install a VM in Hyper-V and Linux can access the Raid.
I'm running W10P at a i7 /16 GB Ram. 4GB for a Ubuntu VM with direct attached SD to the VM, is running 24/7 with Nextcloud without problems
3Dscrewer
Users browsing this forum: No registered users and 81 guests
