NAS Folder not Found
Postby Timmeh » Mon Jun 03, 2019 12:09 pm
Hi all,
Newbie here. Having problems getting subsonic the find my music folder on my WD MyCloud NAS drive.
Have followed the step by step guides in both the subsonic setup manual and this: http://monroeworld.com/android/subsonic/ and have inputted the correct login details for the service, at which point both guides suggest Subsonic should be able to access the folder, however it is still not able to access it.
The drive is mounted in windows with a path of X:\FOLDER_NAME. It is on an external hard drive connected to my NAS. This is the path that I have used to locate the folder in subsonic. Is this the correct path? To my mind this is the only variable that could be causing it to not be found.
Any advice would be massively appreciated.
Best,
Chris.
Timmeh
Users browsing this forum: No registered users and 81 guests
