Subsonic broken - can't access settings and no music shown
Postby pinkmoon » Thu Jun 06, 2019 10:53 am
I recently noticed subsonic wasn't working on one of my mobile apps, so I checked the desktop/browser app and turns out no music is showing in the main window and the left hand menu isn't available at all. Instead if just shows what it can (in the small space available) of the error message. Key point seems to be "org.springframework.dao.TransientDataAccessResourceException".
I've seen other posts on here with similar sounding issues, but not obvious fix. Seems it may have been caused by temporary lack of disk space - maybe this corrupted a key file and the database hasn't been able to update/fix itself? Also seems others have tried to reinstall subsonic and/or java with no success.
Any suggestions / help anyone can offer?
Thanks.
Basic copy of error message below:
Error
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
Java version Oracle Corporation 1.8.0_152
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 26 of 40 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:48)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:87)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:157)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:45)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]
... 65 more
pinkmoon
Re: Subsonic broken - can't access settings and no music sho
Postby PEC » Wed Jun 12, 2019 5:37 pm
It looks like your DB got borked - have you tried cleaning up database and re-scanning files?
PEC
Postby pinkmoon » Wed Jun 12, 2019 10:13 pm
Can't access settings, so unable to rescan - should I just delete the db file and have it rebuild?
Thanks.
pinkmoon
Postby PEC » Thu Jun 13, 2019 2:53 am
Yeah try that
PEC
Postby pinkmoon » Thu Jun 13, 2019 9:07 pm
Seem to have sorted it. Not sure it was due to me deleting the entire db folder, reinstalling the whole thing and/or setting the cache parts of the property file in the db folder = 0 (as spotted in a GitHub post somewhere). Either way, I have been able to get to the settings panel now, have reset everything and it's rescanning :)
Just frustrating that I seems to have this or a similarly fatal issue with ss every year or two :(
Thanks anyone. Faith and persistence appear to have once again paid off! :)
pinkmoon
Users browsing this forum: No registered users and 118 guests
