Subsonic and (some) FLAC files
Postby dokho » Mon Jun 10, 2019 4:22 pm
Hi !
I've a problem with subsonic and some (not all) FLAC files.
Problem Description: files don't play
Playback Application and version: web interface (firefox) / DSub on Android
Subsonic Version: Subsonic Premium 6.1.5 (build 759abe) – 1 décembre 2018
Server Version: jetty-6.1.x, java 1.8.0_212, HSQLDB, Linux (134,6 MB / 594,0 MB)
Hardware Platform: Debian stretch in an lxc contenair on Proxmox 5
Java Memory Limit: SUBSONIC_ARGS="--max-memory=1000"
Output from ffmpeg -i:
ffmpeg version 3.2.14-1~deb9u1 Copyright (c) 2000-2019 the FFmpeg developers
  built with gcc 6.3.0 (Debian 6.3.0-18+deb9u1) 20170516
  configuration: --prefix=/usr --extra-version='1~deb9u1' --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libebur128 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 34.101 / 55. 34.101
  libavcodec     57. 64.101 / 57. 64.101
  libavformat    57. 56.101 / 57. 56.101
  libavdevice    57.  1.100 / 57.  1.100
  libavfilter     6. 65.100 /  6. 65.100
  libavresample   3.  1.  0 /  3.  1.  0
  libswscale      4.  2.100 /  4.  2.100
  libswresample   2.  3.100 /  2.  3.100
  libpostproc    54.  1.100 / 54.  1.100
Input #0, flac, from '***.flac':
  Metadata:
    encoded_by      : Exact Audio Copy   (Burst Modus)
  Duration: 00:05:23.03, start: 0.000000, bitrate: 1008 kb/s
    Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
Last ten log file lines:
tail -f /var/subsonic/subsonic_sh.log
5094 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
[GC (Metadata GC Threshold)  218664K->49716K(329728K), 0,0189806 secs]
[Full GC (Metadata GC Threshold)  49716K->47490K(404480K), 0,1323557 secs]
6425 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 5575 ms
6647 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
6647 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
6649 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@36681447: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Mon Jun 10 18:05:16 CEST 2019]; parent: org.springframework.web.context.support.XmlWebApplicationContext@7586beff
6650 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
6737 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@36681447]: org.springframework.beans.factory.support.DefaultListableBeanFactory@3dfa819
6802 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@3dfa819: defining beans [leftController,artistsController,rightController,statusController,mainController,playlistController,playlistsController,bookmarksController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastChannelsController,internetRadioController,internetRadioStreamController,podcastChannelController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,sonosSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,videoConversionSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,artistImageController,captionsController,avatarController,statusChartController,userChartController,m3uController,streamController,hlsController,segmentController,videoPlayerController,videoConverterController,externalPlayerController,downloadController,premiumSettingsController,multiController,wapController,restController,dbController,premiumSettingsValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@5d534f5d
[GC (Allocation Failure)  240002K->57138K(439296K), 0,0130485 secs]
7502 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 855 ms
7512 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
7542 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
7548 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
7579 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.0.246:9412](local),objID:[0:0:0, 0]]]]
26816 [btpool0-6] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0-FINAL on jetty-6.1.x / JDK 1.8.0_212 from Oracle Corporation at
27255 [btpool0-6] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
27270 [btpool0-6] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
[GC (GCLocker Initiated GC)  284473K->92616K(456192K), 0,0726093 secs]
Note that the same files play right on Logitech Media Server.
Regards,
PS: Sorry for my (bad) english.
dokho
Users browsing this forum: No registered users and 81 guests
