Custom url routing to wrong External IP
Postby innerchi » Thu Jun 27, 2019 7:16 pm
My custom url https://{name}.subsonic.org is routing to an incorrect external IP.
If I manually enter the correct external IP:port into a browser, it works fine.
I also tried configuring a different custom URL and it routed the same way, to the same wrong external IP.
innerchi
Re: Custom url routing to wrong External IP
Postby williamsdb » Wed Jul 10, 2019 6:35 am
Hi
I have the same problem. To get round it I have gone to duckdns.org and created my own address and am using this instead but it does require more work to set it up. Hopefully there'll be a fix soon.
N
williamsdb
Postby wjaz » Mon Aug 26, 2019 10:25 pm
Hey all-
Same issue here with my custom url, I have access outside my network only if I specify my external IP and forwarded port. I will add that the custom url does work inside my network (will correctly point toward server's internal IP).
Seems to have coincided with letting my premium subscription lapse for a couple days prior to renewing. Anyway, would appreciate it if anyone has found a solution, I would like to avoid re-installing!
thanks
wjaz
Postby omar671007 » Wed Sep 18, 2019 2:32 am
Hi All,
I also got the issue after licensed, the IP address is different between my subsonic site and actual domain IP, but I can access my subsonic site by actual IP.
As I checked by ping, my subsonic site be setting to subsonic official WWW website, not my server External IP. But I got the successfully information in Settings => Network page for "easy-to-remember address" (Status: Successfully registered web address. )
Can anyone help me to solve it? Thanks a lot!
omar671007
Users browsing this forum: No registered users and 99 guests
