99% of music stops playing + spinning icon
Postby nickmv » Tue Jul 23, 2019 7:01 pm
I've had an issue for almost a year now that I can no longer overlook.
Basically for 99% of my music collection, when I try to play a song, I can hardly ever finish a song without it stopping mid-music and throwing the spinning icon (presumably "buffering"), and it freezes up there.
In order to fix it, I have to advance through the track to a later un-played portion, then go back again. Again, this happens 99% of the time.
What gives?
-Win 10 machine w/ tons of RAM, little to no CPU usage
- Comcast connection with 250mbps down, 30mbps up --- WAY MORE than capable of sending music in a matter of seconds
Yet Subsonic continually fails me on a daily basis. I love this program but I'm about to ditch it once and for all if this can't be resolved.
nickmv
Re: 99% of music stops playing + spinning icon
Postby 3Dscrewer » Wed Jul 24, 2019 7:59 pm
Read the posting by your self and try to guess what we should answer ....
I have round about 260.000 Titles in my library and tons of Videos without Problems. Lame VB0, Lame CBR 320, AAC, ALAC, FLAC and high resolution 96-24 and up ...
The only Problem I have is the caching of the iPhone Apps play:Sub and AVsub because they are using (probably) the same buggy caching 3rd Party Library.
I guess the problem is in your configuration, but we are no clairvoyants. Post a part of the logfiles where we can see more.
Imho you will have a problem in/with the decoder string.
Since you are having Tons of Ram (wtf is that?) it should be no Problem to do a new setup within Minutes. My 260.000 Titles are scanned within 5 Minutes ...
BTW... Ditch it if you like .... and try to find a better one on that cheap base .., :wink:
3Dscrewer
Users browsing this forum: No registered users and 100 guests
