(Solved) New Tomcat Install - Music will not play
Postby jonathanroz » Wed May 13, 2009 12:11 am
I have been running Subsonic Windows version for a while now. I have also been running the Standalone on an Ubuntu box with no issues.
I decided to load Tomcat on my windows xp pc and install the WAR version (3.6). I am running Tomcat 5.5
Everything seems to work fine except when I add things to my playlist and push play nothing happens. I look in the Subsonic log and there is nothing at all. Not the normal "starting stream" message.
I have never used Tomcat before so maybe I am missing something simple, but everything else seems to work so I am at a loss. This same issue occurs whether I am accessing from the local PC or over the network. If I choose an external player and push play it will open Media Monkey (my external player) but nothing ever plays.
Any ideas?
jonathanroz
Postby jonathanroz » Wed May 13, 2009 8:26 pm
FYI I installed 3.7 and had the same issue. I removed it from the work and webapp folder and tried 3.6 again, this time renaming it to Music instead of Subsonic just in case it was having an issue since I am also running a Subsonic Windows install on the same xp machine.
The Windows one has its Subsonic default folder moved to D: instead of C: so I wouldnt think there would be an issue with that but who knows.
Now installed 3 different times and always the same issue. Pushing play does nothing, but all other functionality works.
jonathanroz
Postby jonathanroz » Wed May 13, 2009 10:00 pm
I changed the port in tomcat and it works now... very weird. I wasnt using a standard port so not sure where the conflict was.
jonathanroz
