Meanwhile streaming on index page is just working well.
I am using 6.1.5 (build 759abe) version on my custom Ubuntu 18.04.3 machine. I tried this on Chrome and Firefox.
Have any ideas about this issue?
G8DHE wrote:On the home page tap the Hamburger menu once and the media folders should appear below the option menu's
thoto wrote:Hi,
I faced the exact same problem as you do, but there's more:
I used to use v6.0 (build a7857c) that was installed when using "plugins" on FreeNAS systems. And everything was working fine.
Then, one day, the problem you described simply appeared, without any other change on my side...
So, I did a fresh install on a dedicated Debian 9 VM, and installed a fresh 6.1.5 (build 759abe)... And unexpectedly, the problem showed again...
I updated the atabase, checked everything related to file permissions and so on (since I use a setup not running subsonic as root user).... no luck..
Anyway, as I was beginning to lose hope, I tried another database refresh from subsonic GUI.... And now everything seems to be fixed...
So, I imagine it may be related to file ownership in the /var/subsonic/db folder .... And maybe you need to refesh the database after having the file permissions changed...
Users browsing this forum: No registered users and 114 guests
