Cannot launch on Tomcat7
Postby spookybathtub » Mon Oct 14, 2019 6:59 am
Hello. I've been away from this project for several months, but I'm now trying to get my server back up and running. I previously had Subsonic 5.1 running on Tomcat7 on Ubuntu. I've installed loads of OS updates and I suspect that is what broke Subsonic. Now it fails to deploy the WAR. I tried removing it and deploying the latest version 6.1 WAR, but it gives the same error. I think I've tracked it down to this database error but I don't know how to fix it. I don't think I've customized anything with the database, it should just be as default.
java.sql.SQLException: User not found: SA
# cat subsonic.log
[2019-10-13 23:38:20,605] INFO HsqlDaoHelper - Checking database schema.
[2019-10-13 23:38:34,342] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.hsql.Schema25.execute(Schema25.java:21)
   at net.sourceforge.subsonic.dao.DaoHelper.init(DaoHelper.java:27)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:498)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5068)
   at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5584)
   at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
   at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
   at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
   at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
   at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1091)
   at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1980)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
   at java.util.concurrent.FutureTask.run(FutureTask.java:266)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.sql.SQLException: User not found: SA
   at java.sql.DriverManager.getConnection(DriverManager.java:664)
   at java.sql.DriverManager.getConnection(DriverManager.java:208)
   ... 52 more
[2019-10-13 23:38:35,065] INFO SettingsService - Java: 1.8.0_222, OS: Linux
[2019-10-13 23:38:35,132] INFO VersionService - Resolved local Subsonic version to: 6.1.5
spookybathtub
Re: Cannot launch on Tomcat7
Postby spookybathtub » Mon Oct 21, 2019 2:49 am
Something was corrupt in the database, so I trashed the whole db folder. Maybe if I have time later I will try to recover some of the ratings, etc.
spookybathtub
Users browsing this forum: No registered users and 101 guests
