PIA VPN & Subsonic
PIA VPN & Subsonic
Postby burn913 » Sat Nov 16, 2019 2:29 pm
I recently started using the Private Internet Access VPN on my Windows 10 machine that runs Subsonic. Does anyone have a guide or advice on how to run Subsonic through PIA VPN? I currently have a split tunnel set up, which is a new PIA feature. That allows Subsonic to use my normal connection and not go through the VPN. This works fine for me now but I'd rather have the Subsonic traffic go through the VPN.
On a related note, while the split tunneling is working great to access my Subsonic out of my home network, I can no longer access it within my network. I confirmed that turning off the VPN restores my ability to access Subsonic within the network. I'm currently using a specific PIA server with port forwarding enabled. Not sure if that matters.
Any help would be greatly appreciated! I'm new to using VPNs so I'm a bit of a newbie in that regard.
burn913
