NAS not visible to Subsonic
Postby Richmilnix » Mon Apr 27, 2020 4:03 pm
I'm sure this is a NAS management question, rather than a Subsonic-specific question; I'm hoping other users have the answer.
My primary use, in the house, is running Roon on a headless Windows terminal to listen to music stored on two NAS. Over the winter, a brownout scrambled the firmware on one NAS (a Buffalo LinkStation) while leaving the data intact; the process of replacing it stretched out over more than a month.
I'm now back up and running, and Roon sees the contents of both machines fine, but Subsonic (which runs on the same Windows machine) doesn't see the folder on the new LinkStation that contains the music files.
Subsonic service on Windows is running as logged-in local user. Security Properties of NAS directories (one working and new invisible LinkStation) appear to be identical: owner is root, permission on live folder is Everyone / Full control.
Problem Description:
Troubleshooting Steps: (A list of the steps you have taken to try to solve this problem yourself)
Playback Application and version: Subsonic www (via custom URL, working fine)
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server Version: jetty-6.1.x, java 1.8.0_152, HSQLDB, Windows 10 (66.5 MB / 145.0 MB)
Hardware Platform: Win10
Java Memory Limit: 150MB? Not labeled quite that way
Problem Filename: -
Output from ffmpeg -i: - not recognized (I don't use this for anything except streaming music)
Last ten log file lines:
[code][4/27/20 3:08:13 AM EDT] INFO MediaScannerService Scanned media library with 68750 entries.
[4/27/20 3:08:15 AM EDT] INFO MediaScannerService Scanned media library with 69000 entries.
[4/27/20 3:08:16 AM EDT] INFO MediaScannerService Scanned media library with 69250 entries.
[4/27/20 3:08:18 AM EDT] INFO MediaScannerService Scanned media library with 69500 entries.
[4/27/20 3:08:19 AM EDT] INFO MediaScannerService Scanned media library with 69750 entries.
[4/27/20 3:08:21 AM EDT] INFO MediaScannerService Scanned media library with 70000 entries.
[4/27/20 3:08:22 AM EDT] INFO MediaScannerService Scanned media library with 70250 entries.
[4/27/20 3:08:23 AM EDT] INFO MediaScannerService Scanned media library with 70500 entries.
[4/27/20 3:08:25 AM EDT] INFO MediaScannerService Scanned media library with 70750 entries.
[4/27/20 3:08:26 AM EDT] INFO MediaScannerService Scanned media library with 71000 entries.
[4/27/20 3:08:28 AM EDT] INFO MediaScannerService Scanned media library with 71250 entries.
[4/27/20 3:08:29 AM EDT] INFO MediaScannerService Scanned media library with 71500 entries.
[4/27/20 3:08:31 AM EDT] INFO MediaScannerService Scanned media library with 71750 entries.
[4/27/20 3:08:32 AM EDT] INFO MediaScannerService Scanned media library with 72000 entries.
[4/27/20 3:08:33 AM EDT] INFO MediaScannerService Scanned media library with 72250 entries.
[4/27/20 3:08:34 AM EDT] INFO MediaScannerService Scanned media library with 72359 entries.
[4/27/20 3:08:34 AM EDT] INFO MediaScannerService Marking non-present files.
[4/27/20 3:08:42 AM EDT] INFO MediaScannerService Marking non-present artists.
[4/27/20 3:08:42 AM EDT] INFO MediaScannerService Marking non-present albums.
[4/27/20 3:08:42 AM EDT] INFO MediaScannerService Completed media library scan.
[4/27/20 3:08:44 AM EDT] INFO PlaylistService Starting playlist import.
[4/27/20 3:08:46 AM EDT] INFO PlaylistService Completed playlist import.
[4/27/20 3:23:05 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 4:25:13 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 5:27:21 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 6:29:29 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 7:31:37 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 8:33:46 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 9:35:55 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 9:41:27 AM EDT] INFO MusicFolderDao Deleted music folder with ID 11
[4/27/20 9:41:27 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 9:41:42 AM EDT] INFO MusicFolderDao Created music folder \\192.168.1.189\wmrf
[4/27/20 9:41:42 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 9:44:22 AM EDT] INFO MusicFolderDao Deleted music folder with ID 12
[4/27/20 9:44:23 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 9:44:40 AM EDT] INFO MusicFolderDao Created music folder \\192.168.1.189\wmrf
[4/27/20 9:44:40 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 10:14:41 AM EDT] INFO MusicFolderDao Created music folder \\LS220DB0A4
[4/27/20 10:14:41 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 10:15:11 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 10:38:03 AM EDT] INFO NetworkService Successfully forwarding port 4040.
[4/27/20 10:41:31 AM EDT] INFO MusicFolderDao Deleted music folder with ID 13
[4/27/20 10:41:31 AM EDT] INFO MusicFolderDao Deleted music folder with ID 14
[4/27/20 10:41:31 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 10:45:54 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 10:46:09 AM EDT] INFO MusicFolderDao Created music folder \\192.168.1.189\wmrf
[4/27/20 10:46:09 AM EDT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Apr 28 03:00:00 EDT 2020
[4/27/20 11:40:12 AM EDT] INFO NetworkService Successfully forwarding port 4040.[/code]
Richmilnix
Re: NAS not visible to Subsonic
Postby 3Dscrewer » Mon Apr 27, 2020 9:07 pm
Are you using that path to the music folder? \\192.168.1.189\wmrf
Why not mapping the path to a windows drive i.e X:\wmrf? I'm not sure if subsonic can handle your path ...
If you are having no Desktop at all, this is the command line.
net use X: \\192.168.1.189\wmrf /user:name password /persistent:Yes
The Persistent switch is only needed if the drive should be available after reboot
3Dscrewer
Postby Richmilnix » Mon May 04, 2020 10:20 pm
Woops, I forgot to reply -
Thanks, your suggestion did the trick! I didn't map it, but I remembered that the drive had an SMB alias and used that. My second NAS (a WD) is visible via IP, so I don't know why the Buffalo isn't, but it doesn't matter.
Thanks again!
Richmilnix
Postby 3Dscrewer » Wed May 06, 2020 8:40 am
Thanks for your reply. I'm spending a lot time to try to help. In most cases there is no information, also for other user, what the failure was.
3Dscrewer
