Synology, where are the Playlists saved?
Postby Julius1569 » Sat Jun 06, 2020 1:01 pm
I use Subsonic on my Synology DS1512+ NAS server.
Now I would like to know in which folder the plalists I created are stored.
Can anyone help?
Best Regards,
Bernd
Julius1569
Re: Synology, where are the Playlists saved?
Postby G8DHE » Sat Jun 06, 2020 2:38 pm
In the database.
You could choose to save them as well by "Exporting" them to a folder, possibly the one it reads for "Import playlist from" then you have them saved for future reference as required.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby Julius1569 » Sun Jun 07, 2020 10:53 am
Hi G8DHE,
Thanks for your answer.
How can I find the playlist in the data base?
I haven't the opportunity to export the playlists from Subsonic, because the programm doesn't start.
My basic problem:
Subsonic runs on a Synolgy NAS Server DS1512+.
The Installed version is an older one: 6.1.5
Every time I try to start Subsonic, I get the following error message:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
To solve this problem I like to do a reinstallation of Subsonic.
Before I do the reistallation I like to save a backup from my playlists.
This is the reason, why I ' am looking for the place where the playlists are saved.
Could you help?
Best regards,
Bernd
Julius1569
Postby G8DHE » Sun Jun 07, 2020 1:00 pm
No I haven't needed to get into the db structure, have you tried searching in the forum or maybe the API.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby 3Dscrewer » Sun Jun 07, 2020 1:30 pm
For new setup I have only copied the subsonic folder and back to the new setup, even if the db folder should be enough
3Dscrewer
Postby Julius1569 » Tue Jun 09, 2020 7:13 am
Ok.
I will still searching in the forum to find a solution.
Thanks for your answers.
Julius1569
