m4a reported as 3:50 but only plays for 2:17
Postby jgn » Fri Jun 26, 2020 1:04 am
In the regular interface, a song (an .m4a) is listed as being 3 minutes and 50 seconds.
Then when I use the built-in player, it flashes 3:50. Then it goes to 0:00 and quickly interates up, stopping at 2:17.
Other songs show the same pattern, but with different final lengths.
The track plays the full 3:50 in the MacOS Music (formerly iTunes).
The install is standard. Haven't changed the ffmpeg settings.
In short:
Track is 3:50.
After a time, it shows 2:17, and only plays for 2:17.
SubSonic issue
Problem Description: Track duration wrong: It first shows the correct time, then goes to 0, then goes up up up and stops at 2:17 (the track is reported in the main interface as 3:50)
Troubleshooting Steps: Nothing let
Playback Application and version: Standard Subsonic Web Interface
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server Version:jetty-6.1.x, java 1.8.0_131, HSQLDB, Mac OS X (85.1 MB / 146.5 MB)
Hardware Platform: Mac mini running Catalina
Java Memory Limit: Unknown. Server has 32 GB RAM
Problem Filename: "01 The Robots [2009 Digital Remaster].m4a"
Output from ffmpeg -i:
jgn@jgnhq Mojo Presents_ The Man Machine % ffmpeg -i "01 The Robots [2009 Digital Remaster].m4a"
ffmpeg version 4.3 Copyright (c) 2000-2020 the FFmpeg developers
  built with Apple clang version 11.0.3 (clang-1103.0.32.62)
  configuration: --prefix=/usr/local/Cellar/ffmpeg/4.3_1 --enable-shared --enable-pthreads --enable-version3 --enable-avresample --cc=clang --host-cflags= --host-ldflags= --enable-ffplay --enable-gnutls --enable-gpl --enable-libaom --enable-libbluray --enable-libdav1d --enable-libmp3lame --enable-libopus --enable-librav1e --enable-librubberband --enable-libsnappy --enable-libsrt --enable-libtesseract --enable-libtheora --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-lzma --enable-libfontconfig --enable-libfreetype --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librtmp --enable-libspeex --enable-libsoxr --enable-videotoolbox --disable-libjack --disable-indev=jack
  libavutil      56. 51.100 / 56. 51.100
  libavcodec     58. 91.100 / 58. 91.100
  libavformat    58. 45.100 / 58. 45.100
  libavdevice    58. 10.100 / 58. 10.100
  libavfilter     7. 85.100 /  7. 85.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  7.100 /  5.  7.100
  libswresample   3.  7.100 /  3.  7.100
  libpostproc    55.  7.100 / 55.  7.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '01 The Robots [2009 Digital Remaster].m4a':
  Metadata:
    major_brand     : M4A
    minor_version   : 0
    compatible_brands: M4A mp42isom
    creation_time   : 2020-06-25T12:23:31.000000Z
    title           : The Robots [2009 Digital Remaster]
    artist          : Kraftwerk
    composer        : Bartos/Schneider/Hütter
    album           : Mojo Presents: The Man Machine
    genre           : Electronica
    track           : 1/15
    disc            : 1/1
    date            : 2009
    compilation     : 1
    gapless_playback: 0
    encoder         : Music 13.0.5.14
    Encoding Params : vers
    iTunNORM        :  00000430 00000422 000031C7 0000564D 00017CAD 00007060 00007EF2 00007EF4 00015E79 000293AE
    iTunes_CDDB_1   : B711560F+333002+15+150+17472+47583+62361+84687+106762+120772+131263+140874+161815+177898+196520+233898+256782+314570
    iTunes_CDDB_TrackNumber: 1
  Duration: 00:03:50.96, start: 0.000000, bitrate: 880 kb/s
    Stream #0:0(und): Audio: alac (alac / 0x63616C61), 44100 Hz, stereo, s16p, 880 kb/s (default)
    Metadata:
Log:
[6/25/20 7:18:25 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/02 45_33 (Pilooski Remix).m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:18:35 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:18:45 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/03 Slow Motion.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:32:32 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:32:37 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:33:18 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:33:28 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:33:33 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:35:12 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/01 The Robots [2009 Digital Remaster].m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[6/25/20 7:37:29 PM CDT]    INFO   TranscodeInputStream   Starting transcoder: /Library/Application Support/Subsonic/transcode/ffmpeg -i /Users/jgn/Music/Music/Media.localized/Compilations/Mojo Presents_ The Man Machine/02 45_33 (Pilooski Remix).m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
jgn
Re: m4a reported as 3:50 but only plays for 2:17
Postby jgn » Fri Jun 26, 2020 1:10 am
Ah, weird tidbit: Only Firefox. Duration is correct in Chrome and Safari.
jgn
Users browsing this forum: No registered users and 74 guests
