Freenas and subsonic Port problem
Postby oxide[NL] » Fri May 22, 2009 6:22 pm
hello im not sure where i need to post this,. here or the freenas forum
my problem is, i want subsonic to run on port 80
but,.. freenas as a build in webserver that really likes port 80
even when i disable freenas his webserver still it wont release the port :(
So,.. my question is what can i do ?
because i want an url like " music-subsonic.nl "
and not " music-subsonic.nl:8080 "
PS sorry for my bad english ( blame my teacher ! )
oxide[NL]
Postby oxide[NL] » Fri May 22, 2009 9:07 pm
freenas gui = port 112
Result the same,. wont open subsonic on port 80
freenas webserver disabled , result still wont work
switched the freenas gui to port 80
gui works on port 80
i dont get it,. why would freenas gui work on port 80
and subsonic not, doesnt make any sense
oxide[NL]
Postby sgx1 » Tue May 26, 2009 5:07 pm
Just to verify your FreeNAS configuration is being saved, when you changed the GUI Port to 112, were you able to access the GUI on that port?
sgx1
