Podcast stops when screen turns off
Postby enix » Thu Aug 27, 2020 5:03 pm
I can see from the log what the "problem is" but google and me being dumb isn't helping.
Problem Description: This is using a phone app (dsub) but I think its a subsonic error. When the pod is downloading it starts playing while downloading. It will continue to play until the screen timesout or i manually lock the screen(screen off). Once the screen goes off the pod stops playing and downloading and will not restart until i clear the partially downloaded file. This happens with some pods but not all.
Troubleshooting Steps: Changed Java versions. Fresh install of subsonic. Playing with transcoding on/off. messed with player settings.
Playback Application and version: dsub, from play store, version 5.4.4
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server Version: jetty-6.1.x, java 1.8.0_265, HSQLDB, Linux (79.2 MB / 145.5 MB)
Hardware Platform: Debian
Java Memory Limit: unsure
Problem Filename: this feed plays fine, i can close the screen as soon as i hit play and it will work fine https://rss.art19.com/todd-n-tyler-radio-empire-podcast
this is one feed that throws the error https://feeds.megaphone.fm/clarkhoward
Output from ffmpeg -i: NA
Last ten log file lines:
[8/27/20 11:31:48 AM CDT]   INFO   PodcastService   Starting to download Podcast from https://rss.art19.com/episodes/3bd946c6-0002-494d-b20b-39e55f3e7d29.mp3
[8/27/20 11:31:48 AM CDT]   INFO   PodcastService   Starting to download Podcast from https://rss.art19.com/episodes/6e1ba3af-b0ef-46e7-8a2b-4aecad45d6e1.mp3
[8/27/20 11:31:48 AM CDT]   INFO   PodcastService   Starting to download Podcast from https://rss.art19.com/episodes/358e34a3-0eb2-40a2-8fef-fa03764a4d7a.mp3
[8/27/20 11:32:15 AM CDT]   INFO   PodcastService   Downloaded 20493979 bytes from Podcast https://rss.art19.com/episodes/6e1ba3af-b0ef-46e7-8a2b-4aecad45d6e1.mp3
[8/27/20 11:32:15 AM CDT]   INFO   PodcastService   Starting to download Podcast from https://rss.art19.com/episodes/096b7f24-3274-4536-a893-5f7ee7044292.mp3
[8/27/20 11:32:16 AM CDT]   INFO   PodcastService   Downloaded 20375708 bytes from Podcast https://rss.art19.com/episodes/3bd946c6-0002-494d-b20b-39e55f3e7d29.mp3
[8/27/20 11:32:16 AM CDT]   INFO   PodcastService   Starting to download Podcast from https://rss.art19.com/episodes/56c872bf-b3a8-409f-a0e1-c02c94c45196.mp3
[8/27/20 11:32:20 AM CDT]   INFO   PodcastService   Downloaded 22976671 bytes from Podcast https://rss.art19.com/episodes/358e34a3-0eb2-40a2-8fef-fa03764a4d7a.mp3
[8/27/20 11:32:34 AM CDT]   INFO   PodcastService   Downloaded 19186190 bytes from Podcast https://rss.art19.com/episodes/096b7f24-3274-4536-a893-5f7ee7044292.mp3
[8/27/20 11:32:35 AM CDT]   INFO   PodcastService   Downloaded 20067252 bytes from Podcast https://rss.art19.com/episodes/56c872bf-b3a8-409f-a0e1-c02c94c45196.mp3
[8/27/20 11:39:49 AM CDT]   WARN   RESTFilter   Error in REST API: EofException
[8/27/20 11:39:49 AM CDT]   ERROR   JAXBWriter   Failed to marshal JAXB
[8/27/20 11:39:49 AM CDT]   ERROR   RESTFilter   Failed to write error response.
[8/27/20 11:42:12 AM CDT]   WARN   RESTFilter   Error in REST API: EofException
[8/27/20 11:42:12 AM CDT]   ERROR   JAXBWriter   Failed to marshal JAXB
[8/27/20 11:42:12 AM CDT]   ERROR   RESTFilter   Failed to write error response.
[8/27/20 11:44:51 AM CDT]   WARN   RESTFilter   Error in REST API: EofException
[8/27/20 11:44:51 AM CDT]   ERROR   JAXBWriter   Failed to marshal JAXB
[8/27/20 11:44:51 AM CDT]   ERROR   RESTFilter   Failed to write error response.
[8/27/20 11:44:58 AM CDT]   WARN   RESTFilter   Error in REST API: EofException
[8/27/20 11:44:58 AM CDT]   ERROR   JAXBWriter   Failed to marshal JAXB
[8/27/20 11:44:58 AM CDT]   ERROR   RESTFilter   Failed to write error response.
11:44:51 is when i started an episode from the problem pod. If i start a working pod the log doesn't change.
very much appreciate any help.
enix
Re: Podcast stops when screen turns off
Postby demodulated » Fri Sep 04, 2020 1:57 pm
By chance does your phone have a battery-saving functionality that puts background apps to sleep? You may need to add Dsub to the exemption list.
Does this only happen with podcasts or with all songs?
demodulated
Postby enix » Tue Nov 17, 2020 9:26 pm
I'm back because this is still an issue. Only happens with one pod so far
Not sure what the issue could be.
No battery saving features turned on
enix
