artwork issue
artwork issue
Postby almal100 » Sat Sep 05, 2020 10:26 am
for some reason, a good proportion of my library seemingly didn't load the artwork for albums correctly, below is an example:
https://imgur.com/jFEw7mT
is there a way to reload the artwork? or to fix them one by one? the artwork is all fine on my local rive and embedded in the files.
thanks
almal100
Re: artwork issue
Postby 3Dscrewer » Tue Sep 08, 2020 12:37 pm
Subsonic is running at Windows, Mac and Linux so it is not easy to find a reason.
No further information if jpg, png, tiff or whatever or what size.
For general, setting files and folder of an album to actual date will cause a rescan of the files, or better they will be recognized in subsonic as new by rescan.
3Dscrewer
Re: artwork issue
Postby almal100 » Wed Sep 09, 2020 2:13 pm
sorry, i should have included much more info.
i'm using Windows, artwork will be mainly .jpg or .png, size will vary but probably usually between 300x300 and 1500x1500
causing a rescan of all the files is what i'm looking to do i think, but i'm not quite sure what you mean by this
could you expand on how to do that, please?
thanks for your help
almal100
Re: artwork issue
Postby G8DHE » Wed Sep 09, 2020 2:28 pm
I use TouchPro to set the file folder dates https://www.jddesign.co.uk/products/tou ... uchpro.htm
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Re: artwork issue
Postby almal100 » Wed Sep 09, 2020 4:34 pm
So I'd use this to make it look like the folders were created or modified today, and then rescan?
almal100
Re: artwork issue
Postby G8DHE » Wed Sep 09, 2020 9:01 pm
That's what I do once I see scan problems, just alter the top level folder and set it to propagate down all levels and files.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Re: artwork issue
Postby 3Dscrewer » Sat Sep 12, 2020 10:25 am
A PNG @1500x1500 can have fast 15MB, same Size JPG has 10% of Size, may be that is causing problems. Since you are on windows, I'm using XNview to modify the pictures and optimize the size. I have always 500x500 and they will be 40-60kb in most times .
For MP3 there are different versions for the Tags available where all informations stored. MP3Tag is a free tool for editing the Tags since I know about MP3 (and that is a long time ;-) ) it is well maintained, regular updates and bugfixes.
Using old versions of the Tags can cause also problems
Total Commander is also a neat tool. It is using split screen, nice to copy or move files, a lot more and it can also modify the date of files easily. It is not free, but worse the small money and you can use it by pressing a button at a nag screen.
I'm old, coming from DOS and Norton Commander, can't live without it :-)
3Dscrewer
