Haven't encountered this in the nine years using it
Postby MoreTrife » Thu Oct 29, 2020 8:59 pm
Problem Description: ALL WINDOWS FILLED WITH ERROR MESSAGES: Exception org.springframework.dao.TransientDataAccessResourceException
Message PreparedStatementCallback; SQL
Troubleshooting Steps: rebooted computer...
Playback Application and version: desktop and Dsub
Subsonic Version: not completely sure, 6.1 something. Can't even check it as all windows filled with error message.
Server Version: jetty 6.1.x? unable to check as windows filled with error messages...though connection seems in tact as I can reach server from Dsub and browser outside local network.
Hardware Platform: Windows 10, music on Seagate NAS
Java Memory Limit: 150
Last ten log file lines:
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
... 65 more
Thanks for any help
MoreTrife
Re: Haven't encountered this in the nine years using it
Postby MoreTrife » Thu Oct 29, 2020 10:10 pm
https://photos.app.goo.gl/xsKWaqR5tmpvNnLV6
Link to screenshot of error screen, maybe that will help.
MoreTrife
Postby MoreTrife » Thu Oct 29, 2020 10:17 pm
Now it's partially back having done nothing on my end...Still missing lots of settings and music isn't back. Interface is partially back.
MoreTrife
Postby MoreTrife » Fri Oct 30, 2020 3:47 am
Ugh. Just deleted everything and reinstalled. Guess it was a corrupt database.
MoreTrife
Postby df7 » Sat Jun 05, 2021 7:05 pm
You say you deleted "everything." What do you mean by that?
df7
Postby df7 » Fri Jun 18, 2021 5:51 pm
Figured out that I basically needed to uninstall and reinstall Subsonic on my computer.
df7
Postby G8DHE » Sat Jun 19, 2021 2:16 pm
Why not restore the backup the software makes itself from the db folder ?
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
