why i Cannot scan any files in the directory ?
Postby myrisc » Mon Dec 07, 2020 4:50 am
The deployment is completed without any problems, but no matter which directory is set, the mp3 files in the directory cannot be scanned.Standalone and rpm mode all the same, mp3 cannot be scanned,the log shows 0 found。This problem occurs when using hostus ovz vps,But with other kvm vps, there is no such problem, including local virtual machine testing. The test uses centos 8, the same mp3 file, the same file permissions,Only hostus ovz has a problem. I want to know if it is caused by the ovz architecture or there are other reasons?
myrisc
Re: why i Cannot scan any files in the directory ?
Postby myrisc » Mon Dec 07, 2020 7:14 am
Is it because of the file system?My ovz is like this:/dev/ploop65418p1 2048 157284352 157282305 75G Linux kvm :/dev/sda1 * 2048 125829086 125827039 60G 83 Linux
this is the only difference I found ,
Is it caused by this?
myrisc
Users browsing this forum: No registered users and 85 guests
