Java Version Issues Ubuntu
Postby treed873 » Mon Dec 21, 2020 1:02 pm
I have been running Subsonic for years without issue, but a recent update to openjdk-11-jre has caused it to stop working. I am now getting this error when going to the site: HTTP ERROR: 503. Now, I know that Subsonic requires openjdk-8-jre, and I still have it installed, but a different application requires the newer version of java. I have java 11 as the default. My question is, how do I define the openjdk-8-jre version for subsonic while allowing openjdk-11-jre to be my default?
treed873
Re: Java Version Issues Ubuntu
Postby treed873 » Tue Dec 22, 2020 3:15 pm
So an update to my issue, I reverted back to openjdk-8, rebooted, and Subsonic came back. Unfortunately, I run a minecraft server on this same box, and at some point it will no longer run on java 8. Java is self contained, and can have different versions running at the same time, but I'm not sure how to have subsonic "choose" java 8 when running even if it isn't the default java. If anyone has any ideas on this, I would greatly appreciate it.
Thanks for looking
treed873
Postby acroyear » Wed Dec 23, 2020 2:03 pm
On my Ubuntu box (20.04)
The service is in /etc/init.d/subsonic
In there, it references /usr/bin/subsonic
In /usr/bin/subsonic is
# Use JAVA_HOME if set, otherwise assume java is in the path.
JAVA=java
if [ -e "${JAVA_HOME}" ]
    then
    JAVA=${JAVA_HOME}/bin/java
fi
At the top of that file with the SUBSONIC_ env variables, that's where you can set JAVA_HOME to the jdk8 install location.
Then
sudo service subsonic restart
to bounce it.
No promises, I haven't had to do that yet as I have no need for JDK11 on the same box as a JDK8.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby treed873 » Wed Dec 23, 2020 3:54 pm
So this is the Java section of my subsonic.sh file:
JAVA=java
    then
Do I set my JAVA_HOME like this?
JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64
    then
treed873
Postby treed873 » Wed Dec 23, 2020 6:10 pm
So that worked, and if anyone is dealing with the same issue, here is what I did:
I edited my subsonic.sh file located in my /usr/share/subsonic/ directory, see below:
    then
The only issue that I need to figure out is, when I rebooted subsonic it did not start automatically. I had to run sudo service subsonic start.
A big thank you to acroyear for pointing me in the right direction! If anyone has an idea about the auto start issue, I'd be much obliged.
treed873
Postby cfw34683 » Sun Dec 27, 2020 10:16 pm
This is what i use so that i can have Java 8 and Java 11 installed.
Since i have both installed I used Java 11 by default via
sudo update-alternatives --config java
This allows me to set the PATH default to java 11
I then modified my service file or what ever way you start it up. I use this command to use Java 8
/usr/lib/jvm/java-1.8.0-openjdk-amd64/jre/bin/java -Xmx700m -Xloggc:gc_memory_logs.log -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -Dsubsonic.home=/SOME/PATH/TO/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/music -Dsubsonic.db= -Dsubsonic.defaultMusicFolder=/SOME/PATH/TO/MUSIC -Dsubsonic.defaultPodcastFolder=/SOME/PATH/TO/Podcast -Dsubsonic.defaultPlaylistFolder=/SOME/PATH/TO/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar"
This starts it up with Java 8 while using Java 11 as default for my Minecraft server.
To enable at start use
sudo systemctl enable subsonic
cfw34683
Postby treed873 » Mon Dec 28, 2020 6:13 pm
I used the
to set my default java version to 11. If you don't mind me asking, what version of Ubuntu are you using, and where is your service file?
treed873
Postby cfw34683 » Tue Dec 29, 2020 1:33 am
treed873 wrote:I used the
I am using Ubuntu 20.10
My subsonic file was located in /etc/systemd/system/ also check /usr/lib/systemd/user
cfw34683
Postby treed873 » Tue Dec 29, 2020 2:31 pm
So that is probably the difference. My server is on 16.04, so my subsonic.sh file is located in /usr/share/subsonic/.
treed873
