Subsonic browser error.
Postby luvleggs » Tue Dec 29, 2020 6:56 pm
I can access most of my catalog still using a phone through sonos (my normal access to my library) but when I went to look for a certain new album it wasn't there. Went to my subsonic server and using browser it started throwing errors in all the frames, started with left, then right and then finally any link I select will throw this error. From what I've read this is a corrupt database and requires a full reinstall/rebuild. Hoping that there is a better answer to this than a random blip corrupting it.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
Java version Oracle Corporation 1.8.0_152
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 81 of 92 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:698)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:133)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:137)
at net.sourceforge.subsonic.dao.AbstractDao.namedQuery(AbstractDao.java:91)
at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:265)
at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:266)
at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:168)
at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:85)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:29)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
... 66 more
luvleggs
Re: Subsonic browser error.
Postby luvleggs » Tue Dec 29, 2020 10:26 pm
Sorted by using this article https://wiki.cementhorizon.com/articles/Tech/How%20to%20clean%20up%20a%20corrupted%20Subsonic%20database.html, seems like it comes up enough it should be a sticky item.
luvleggs
Users browsing this forum: No registered users and 87 guests
