Subsonic corrupting data when it crashes
Postby crashoverride025 » Thu Jan 07, 2021 10:06 pm
I'm running Subsonic in a tomcat docker container, and I've noticed that when the container is taken down, it tends to corrupt the database mid write.
subsonic.yml
version: '3'
services:
  subsonic:
    container_name: subsonic
    image: tomcat:9-jdk8
    ports:
       - 9080:8080/tcp
    restart: always
    volumes:
       - ~/subsonic/app:/usr/local/tomcat/webapps
       - ~/subsonic/logs:/usr/local/tomcat/logs
       - ~/subsonic/data:/var/subsonic
       - ~common/Podcast:/content/podcast
       - ~common/Music:/content/music
How can the database be repaired and how does subsonic handle this in tomcat when it's installed as a system service?
Caused by: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 49345 java.io.IOException: org.hsqldb.HsqlException: Value too long
        at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
        at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:68)
        at net.sourceforge.subsonic.dao.PlayerDao.deleteOldPlayers(PlayerDao.java:117)
        at net.sourceforge.subsonic.service.PlayerService.init(PlayerService.java:39)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
        ... 105 more
Caused by: java.sql.SQLException: error in script file line: 49345 java.io.IOException: org.hsqldb.HsqlException: Value too long
        at java.sql.DriverManager.getConnection(DriverManager.java:664)
        at java.sql.DriverManager.getConnection(DriverManager.java:208)
        ... 119 more
Once it sees that the db is corrupted, the application will fail to start up.
crashoverride025
