Audio drops for ~10 seconds when playing FLAC [solved]
Postby evvywevvy » Fri Feb 26, 2021 8:56 pm
When I am playing music in the web player on my Windows PC in Firefox 86 (64 bit) from my server (FreeBSD 12.1, Subsonic 6.1.6, Tomcat 9.0.37, java 1.8.0_265), the audio drops out for about 10 seconds at a time. The player looks normal, with the song progress ticking up; then the music comes back on its own. This can happen between 0 and 5 times for a song, and generally doesn't happen more than once a minute. This appears only to happen when I am listening to FLAC music. My transcode command is "ffmpeg -i %s -map 0:0 -b:a %bk -v 0 -f mp3 -" which I believe is the default. Ffmpeg is from the pkg repository. There are no entries in the Subsonic log for anything besides registering songs on Last.fm.
If I listen to a song again, the audio drops in the same place(s). I have ideas about what might be happening, but I don't know what to try to fix it.
evvywevvy
Re: Audio drops for ~10 seconds when playing FLAC
Postby evvywevvy » Thu Mar 11, 2021 11:16 pm
Poking around in the settings I discovered that ffmpeg was not installed as a transcoder in /var/subsonic/transcode . I linked in /usr/local/bin/ffmpeg and I don't get the dropouts anymore. Not sure what the original problem was, but I'm not listening hard enough for FLAC vs 320k mp3 to matter, so I'm happy.
evvywevvy
Users browsing this forum: No registered users and 94 guests
