java.lang.ClassFormatError: Truncated class file
Postby robbb » Sun Mar 21, 2021 1:50 pm
Reading through the forum I could not find anybody having the same problem.
- Subsonic installed on an Odroid HC1 with DietPi.
- Had to install "adoptopenjdk-8-hotspot-jre-armhf" in order to get it to work at all
- It is up and running, scanning folders and it shows Albums on Start Page.
- But when I try to access the Index, I get the following error message:
Exception    java.lang.ClassFormatError
Message    Truncated class file
Java version    AdoptOpenJDK 1.8.0_282
Operating system    Linux 4.14.180+
Server    jetty-6.1.x
Memory    Used 90 of 145 MB
Stack trace    java.lang.ClassFormatError: Truncated class file
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:756)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:468)
   at java.net.URLClassLoader.access$100(URLClassLoader.java:74)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:369)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:363)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:362)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:133)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:65)
   at org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:596)
   at org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:147)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:315)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
   at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
I have no idea what to do about it.
Can anyone please help?
Thanx!
robbb
Re: java.lang.ClassFormatError: Truncated class file
Postby robbb » Sun Mar 21, 2021 2:20 pm
I have to add, that I can play an Album as such, but cannot open it.
Getting another error:
Exception    javax.servlet.ServletException
Message    javax.servlet.jsp.JspException: Truncated class file
Server    jetty-6.1.x
Memory    Used 104 of 145 MB
Stack trace    javax.servlet.ServletException: javax.servlet.jsp.JspException: Truncated class file
   at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:854)
   at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:742)
   at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:332)
Caused by: java.lang.ClassFormatError: Truncated class file
   at org.mortbay.jetty.servlet.Dispatcher.include(Dispatcher.java:192)
   at org.apache.taglibs.standard.tag.common.core.ImportSupport.acquireString(ImportSupport.java:296)
   at org.apache.taglibs.standard.tag.common.core.ImportSupport.doEndTag(ImportSupport.java:161)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspx_meth_c_import_0(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:1391)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:471)
   ... 68 more
robbb
