Playlists location?
Playlists location?
Postby gberg » Wed May 05, 2021 7:23 am
Where are playlists stored on a Ubuntu Subsonic installation?
In the config file /var/subsonic/subsonic.properties I see this line: PlaylistFolder=/var/playlists, but there are no playlist files i that folder?
gberg
Re: Playlists location?
Postby acroyear » Wed May 05, 2021 5:08 pm
they're in the database.
using /db.view
select * from playlist
gets you the playlist id
select * from playlist_file where id = 3
gets you the songs (in order) for the playlist - those are 'media_file_id'
join that to media file
select * from playlist_file pf, media_file mf where pf.playlist_id = 3 and pf.media_file_id = mf.id
and there's your contents
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby gberg » Wed May 05, 2021 5:30 pm
Ok, thanks!
But what's the line: PlaylistFolder=/var/playlists for then?
gberg
Postby acroyear » Tue May 11, 2021 11:00 pm
legacy. i think it was how playlists used to be managed in an earlier version.
Joe Shelby
acroyear
Postby Jägs » Wed May 12, 2021 1:32 am
It's also where Subsonic looks for playlists to import (by default).
Jägs
