can someone post the /etc/default/subsonic file contents?
Postby nthali » Sat May 22, 2021 11:56 pm
So i had installed subsonic, and i had java 11 and i added several jar files to fix NoClassDefFound issues, and still couldn't get it to work, so i did a "sudo apt remove subsonic" to see if i could start over.
i noticed that the apt remove command didn't remove the /etc/default/subsonic file or the /var/subsonic folder, so i manually "rm -rf"ed them.
then i re-installed (sudo dpkg -i) subsonic, but this time it didn't create a /etc/default/subsonic file at all.
hence, can someone post their subsonic file so i can copy and paste it into my install?
thanks,
Nilesh
nthali
