A fatal error has been detected by the Java Runtime Environm
Postby mfrt » Mon Jun 14, 2021 3:55 pm
I have Subsonic running on an Odroid-xu4 running Ubuntu 20.04. Recently the subsonic service has been crashing. The subsonic_sh.log shows this:
Any ideas?
164 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@edcd21: display name [org.springframework.context.support.ClassPathXmlApplicationContext@edcd21]; startup date [Mon Jun 14 14:57:58 UTC 2021]; root of context hierarchy
385 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
[GC (Allocation Failure) 4416K->1276K(15872K), 0.0127226 secs]
[GC (Allocation Failure) 5692K->2230K(15872K), 0.0147012 secs]
[GC (Allocation Failure) 6646K->2950K(15872K), 0.0084329 secs]
1613 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@edcd21]: org.springframework.beans.factory.support.DefaultListableBeanFactory@fed156
1653 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@fed156: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
1742 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
Extracting webapp to /var/subsonic/jetty/0cfa60
1868 [main] INFO org.mortbay.log - jetty-6.1.x
[GC (Allocation Failure) 7366K->3706K(15872K), 0.0115864 secs]
[GC (Allocation Failure) 8119K->4142K(15872K), 0.0086288 secs]
[GC (Allocation Failure) 8553K->4092K(15872K), 0.0047316 secs]
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/0cfa60/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[GC (Allocation Failure) 8508K->4423K(15872K), 0.0034269 secs]
[GC (Allocation Failure) 8839K->4393K(15872K), 0.0044103 secs]
[GC (Allocation Failure) 8809K->4355K(15872K), 0.0024504 secs]
[GC (Allocation Failure) 8771K->4368K(15872K), 0.0024921 secs]
[GC (Allocation Failure) 8784K->4347K(15872K), 0.0019766 secs]
3794 [main] INFO / - Initializing Spring root WebApplicationContext
3794 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
[GC (Allocation Failure) 8763K->5083K(15872K), 0.0059580 secs]
3883 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@186beff: display name [Root WebApplicationContext]; startup date [Mon Jun 14 14:58:02 UTC 2021]; root of context hierarchy
[GC (Allocation Failure) 9499K->5442K(15872K), 0.0068539 secs]
4016 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
4260 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
[GC (Allocation Failure) 9858K->5587K(15872K), 0.0047443 secs]
4397 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
4452 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
4520 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
[GC (Allocation Failure) 10003K->5739K(15872K), 0.0043519 secs]
4569 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
[GC (Allocation Failure) 10155K->5981K(15872K), 0.0092100 secs]
[Full GC (System.gc()) 6070K->3826K(15872K), 0.0568957 secs]
5256 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@186beff]: org.springframework.beans.factory.support.DefaultListableBeanFactory@10c12b7
[GC (Allocation Failure) 8263K->4528K(15936K), 0.0055369 secs]
[GC (Allocation Failure) 9008K->4798K(15936K), 0.0062118 secs]
[GC (Allocation Failure) 9278K->4809K(15936K), 0.0053466 secs]
6017 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@10c12b7: defining beans [playerDao,mediaFileDao,artistDao,albumDao,playlistDao,playQueueDao,internetRadioDao,musicFileInfoDao,musicFolderDao,userDao,transcodingDao,podcastDao,avatarDao,shareDao,bookmarkDao,videoConversionDao,daoHelper,mediaFileService,securityService,settingsService,mediaScannerService,searchService,networkService,playerService,playlistService,versionService,statusService,ratingService,musicIndexService,audioScrobblerService,transcodingService,shareService,podcastService,adService,jukeboxService,folderBasedContentDirectory,upnpService,fanartTvService,lastFmService,bookmarkService,videoConversionService,sonosService,metaDataParserFactory,ajaxMultiService,ajaxNowPlayingService,ajaxPlayQueueService,ajaxPlaylistService,ajaxLyricsService,ajaxCoverArtService,ajaxStarService,ajaxTagService,ajaxTransferService,ajaxChatService,localeResolver,loginFailureLogger,net.sourceforge.subsonic.security.SubsonicApplicationEventListener#0,filterChainProxy,httpSessionContextIntegrationFilter,logoutFilter,authenticationProcessingFilter,basicProcessingFilter,restRequestParameterProcessingFilter,basicProcessingFilterEntryPoint,securityContextHolderAwareRequestFilter,rememberMeProcessingFilter,anonymousProcessingFilter,exceptionTranslationFilter,basicExceptionTranslationFilter,filterInvocationInterceptor,accessDecisionManager,rememberMeServices,authenticationManager,daoAuthenticationProvider,userCacheWrapper,ldapAuthenticationProvider,bindAuthenticator,userDetailsServiceBasedAuthoritiesPopulator,ajaxServiceInterceptor,ajaxTagServiceSecure,ajaxTransferServiceSecure,cacheFactory,userCache,mediaFileMemoryCache,cxf,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,sonosEndpoint,sonosHelper]; root of factory hierarchy
[GC (Allocation Failure) 9289K->5203K(15936K), 0.0064229 secs]
6235 [main] INFO org.springframework.jdbc.datasource.DriverManagerDataSource - Loaded JDBC driver: org.hsqldb.jdbcDriver
[GC (Allocation Failure) 9683K->6569K(15936K), 0.0089905 secs]
[GC (Allocation Failure) 11049K->8559K(15936K), 0.0159451 secs]
[GC (Allocation Failure) 13033K->8931K(15936K), 0.0109011 secs]
[GC (Allocation Failure) 13411K->9325K(15936K), 0.0100952 secs]
[GC (Allocation Failure) 13805K->9546K(15936K), 0.0110764 secs]
[Full GC (System.gc()) 9906K->6916K(15936K), 0.1200593 secs]
[GC (Allocation Failure) 11588K->8742K(16776K), 0.0174648 secs]
[GC (Allocation Failure) 13414K->11766K(16776K), 0.0397550 secs]
[GC (Allocation Failure) 16438K->14637K(19336K), 0.0412426 secs]
[Full GC (Allocation Failure) 14637K->14478K(19336K), 0.1518819 secs]
[GC (Allocation Failure) 23559K->20078K(34104K), 0.0887137 secs]
[GC (Allocation Failure) 29550K->26040K(35640K), 0.0862120 secs]
[Full GC (Allocation Failure) 26040K->24913K(35640K), 0.2601810 secs]
[GC (Allocation Failure) 41617K->35278K(60276K), 0.1196918 secs]
[GC (Allocation Failure) 51982K->45576K(62324K), 0.1563178 secs]
[Full GC (Allocation Failure) 45576K->34335K(62324K), 0.3201912 secs]
[GC (Allocation Failure) 57375K->48598K(83084K), 0.1534990 secs]
[GC (Allocation Failure) 71638K->62882K(86028K), 0.2279581 secs]
[Full GC (Allocation Failure) 62882K->35788K(86028K), 0.3491034 secs]
[GC (Allocation Failure) 59788K->50923K(86592K), 0.1439156 secs]
[GC (Allocation Failure) 74923K->65896K(89920K), 0.1970436 secs]
[Full GC (Allocation Failure) 65896K->38780K(89920K), 0.3614050 secs]
[GC (Allocation Failure) 64764K->48545K(93820K), 0.0980134 secs]
[GC (Allocation Failure) 74529K->52349K(93820K), 0.0531202 secs]
[GC (Allocation Failure) 78333K->54460K(93820K), 0.0322775 secs]
[GC (Allocation Failure) 80444K->56529K(93820K), 0.0338735 secs]
[GC (Allocation Failure) 82513K->57798K(93820K), 0.0292585 secs]
[Full GC (Metadata GC Threshold) 61138K->35920K(93820K), 0.4099310 secs]
[GC (Allocation Failure) 61968K->40107K(93884K), 0.0178392 secs]
25893 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
25914 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public net.sourceforge.subsonic.ajax.UploadInfo net.sourceforge.subsonic.ajax.TransferService.getUploadInfo()] with attributes [[ROLE_UPLOAD]]
25914 [main] INFO org.acegisecurity.intercept.method.MethodDefinitionMap - Adding secure method [public java.lang.String net.sourceforge.subsonic.ajax.TagService.setTags(int,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String)] with attributes [[ROLE_COVERART]]
25915 [main] INFO org.acegisecurity.intercept.AbstractSecurityInterceptor - Validated configuration attributes
[GC (Allocation Failure) 66155K->40742K(93884K), 0.0281265 secs]
[GC (Allocation Failure) 66790K->42065K(93884K), 0.0306654 secs]
28914 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization completed in 25120 ms
[GC (Allocation Failure) 68113K->43041K(93884K), 0.0280853 secs]
29453 [main] INFO / - Initializing Spring FrameworkServlet 'subsonic'
29453 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
29455 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@c8f4b9: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Mon Jun 14 14:58:28 UTC 2021]; parent: org.springframework.web.context.support.XmlWebApplicationContext@186beff
29456 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
29587 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@c8f4b9]: org.springframework.beans.factory.support.DefaultListableBeanFactory@dfab87
29774 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@dfab87: defining beans [leftController,artistsController,rightController,statusController,mainController,playlistController,playlistsController,bookmarksController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastChannelsController,internetRadioController,internetRadioStreamController,podcastChannelController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,sonosSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,videoConversionSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,artistImageController,captionsController,avatarController,statusChartController,userChartController,m3uController,streamController,hlsController,segmentController,videoPlayerController,videoConverterController,externalPlayerController,downloadController,premiumSettingsController,multiController,wapController,restController,dbController,premiumSettingsValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@10c12b7
[GC (Allocation Failure) 69089K->42381K(93884K), 0.0218830 secs]
[GC (Allocation Failure) 68429K->42695K(93884K), 0.0142814 secs]
[GC (Allocation Failure) 68743K->43281K(93884K), 0.0158407 secs]
[GC (Allocation Failure) 69329K->44177K(93884K), 0.0252655 secs]
31916 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 2463 ms
31952 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
32025 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
32104 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
32184 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.0.1:9412](local),objID:[0:0:0, 0]]]]
[GC (Allocation Failure) 70225K->47061K(93884K), 0.0394642 secs]
39433 [btpool0-2] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0-FINAL on jetty-6.1.x / JDK 1.8.0_292 from Private Build at
[GC (Allocation Failure) 73109K->54922K(93884K), 0.0844246 secs]
[GC (Allocation Failure) 80970K->60195K(93884K), 0.0777674 secs]
[GC (Allocation Failure) 86243K->65019K(93884K), 0.0678584 secs]
40607 [btpool0-2] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
40639 [btpool0-2] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
[GC (Allocation Failure) 90881K->69519K(95676K), 0.0486192 secs]
[Full GC (Allocation Failure) 69519K->53227K(95676K), 0.5632110 secs]
[GC (Allocation Failure) 88939K->56165K(128844K), 0.0289893 secs]
[GC (Allocation Failure) 91877K->61852K(128844K), 0.0211750 secs]
[GC (GCLocker Initiated GC) 97968K->62911K(128844K), 0.0070546 secs]
[GC (Allocation Failure) 98623K->65866K(128844K), 0.0555662 secs]
[GC (Allocation Failure) 101578K->67130K(128844K), 0.0081758 secs]
[GC (Allocation Failure) 102842K->65537K(128844K), 0.0065693 secs]
[GC (Allocation Failure) 101249K->65654K(128844K), 0.0070477 secs]
[GC (Allocation Failure) 101366K->66321K(128844K), 0.0243795 secs]
[GC (Allocation Failure) 102025K->67419K(128844K), 0.0432518 secs]
[GC (Allocation Failure) 102748K->68339K(128844K), 0.0414164 secs]
[GC (Allocation Failure) 103778K->75039K(128844K), 0.0492168 secs]
[GC (Allocation Failure) 110751K->75864K(128844K), 0.0220336 secs]
[GC (Allocation Failure) 111556K->75776K(128844K), 0.0160143 secs]
[GC (Allocation Failure) 111488K->76371K(128844K), 0.0467347 secs]
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00000000, pid=15904, tid=0xa02ff460
# JRE version: OpenJDK Runtime Environment (8.0_292-b10) (build 1.8.0_292-8u292-b10-0ubuntu1~20.04-b10)
# Java VM: OpenJDK Client VM (25.292-b10 mixed mode linux-aarch32 )
# Problematic frame:
# C 0x00000000
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /usr/share/subsonic/hs_err_pid15904.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
mfrt
