Songs ending early
Songs ending early
Postby xnor » Wed Nov 03, 2021 4:27 pm
I recently moved my music and subsonic installation over to a freebsd jail running on truenas and I'm experiencing something I hadn't experienced before...
While playing an album (flac) the playback of most songs ends before the end of the song, and the next song starts playing... basically, it is as if i pushed "next" 1/2 way through each track.
The log doesn't indicate any sort of error:
[11/3/21 8:58:58 AM PDT]    INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -i /media/music/deutsch_amerikanische_freundschaft/alles_ist_gut/02-der_mussolini.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
[11/3/21 9:01:10 AM PDT]    INFO   TranscodeInputStream   Starting transcoder: /var/subsonic/transcode/ffmpeg -i /media/music/deutsch_amerikanische_freundschaft/alles_ist_gut/03-rote_lippen.flac -map 0:0 -b:a 320k -v 0 -f mp3 -
there was no user interaction here, 02-der_mussolini.flac is 3:55 long but it was only played for 2:12
I'm using the suggested transcode and downsample settings, I'm using the ffmpeg binary from the package manager, running the 'standalone' subsonic installation.
Any ideas whats up?
I figure this is likely a dup topic, but I couldn't find a thread on this... feel free to just point me to it if you know of it.
License Subsonic Premium
Version 6.1.6 (build 0cfa60) – November 10, 2019
Server jetty-6.1.x, java 1.8.0_302, HSQLDB, FreeBSD (96.0 MB / 144.0 MB)
Truenas Jail, FreeBSD
[xnor@subsonic ~]$ ffmpeg -i
ffmpeg version 4.4 Copyright (c) 2000-2021 the FFmpeg developers
  built with FreeBSD clang version 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-0-gef32c611aa2)
  configuration: --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --pkgconfigdir=/usr/local/libdata/pkgconfig --disable-static --enable-shared --enable-pic --enable-gpl --enable-avresample --cc=cc --cxx=c++ --disable-alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --enable-libaom --disable-libaribb24 --enable-asm --enable-libass --disable-libbs2b --disable-libcaca --disable-libcdio --disable-libcelt --disable-libcodec2 --enable-libdav1d --disable-libdavs2 --disable-libdc1394 --disable-debug --enable-htmlpages --enable-libdrm --disable-libfdk-aac --disable-libflite --enable-fontconfig --enable-libfreetype --enable-frei0r --disable-libfribidi --disable-gcrypt --disable-libglslang --disable-libgme --enable-gmp --enable-gnutls --enable-version3 --disable-libgsm --enable-iconv --disable-libilbc --disable-libjack --disable-libklvanc --disable-libkvazaar --disable-ladspa --enable-libmp3lame --disable-liblensfun --disable-libbluray --disable-librsvg --disable-librtmp --enable-libxml2 --disable-lto --disable-lv2 --disable-mbedtls --disable-libmfx --disable-libmodplug --disable-libmysofa --disable-nonfree --disable-openal --disable-opencl --disable-opengl --disable-libopenh264 --disable-libopenjpeg --disable-libopenmpt --disable-openssl --disable-libopenvino --enable-optimizations --enable-libopus --disable-pocketsphinx --disable-libpulse --disable-librabbitmq --disable-librav1e --disable-librist --enable-runtime-cpudetect --disable-librubberband --disable-sdl2 --disable-libsmbclient --disable-libsnappy --disable-sndio --disable-libsoxr --disable-libspeex --disable-libsrt --disable-libssh --disable-libtensorflow --disable-libtesseract --enable-libtheora --disable-libtwolame --disable-libuavs3d --enable-libv4l2 --enable-vaapi --disable-vapoursynth --enable-vdpau --disable-libvidstab --disable-libvmaf --enable-libvorbis --disable-libvo-amrwbenc --enable-libvpx --disable-vulkan --disable-libwebp --enable-libx264 --enable-libx265 --disable-libxavs2 --enable-libxcb --enable-libxvid --disable-outdev=xv --disable-libzimg --disable-libzmq --disable-libzvbi
  libavutil      56. 70.100 / 56. 70.100
  libavcodec     58.134.100 / 58.134.100
  libavformat    58. 76.100 / 58. 76.100
  libavdevice    58. 13.100 / 58. 13.100
  libavfilter     7.110.100 /  7.110.100
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  9.100 /  5.  9.100
  libswresample   3.  9.100 /  3.  9.100
  libpostproc    55.  9.100 / 55.  9.100
Missing argument for option 'i'.
Error splitting the argument list: Invalid argument
xnor
Re: Songs ending early
Postby xnor » Mon Nov 08, 2021 5:56 pm
looks like it might be the same as this age old bug? I am seeing that the length computed in the player is incorrect.. i can manually advance the song past that point and play to the end..
http://forum.subsonic.org/forum/viewtopic.php?f=2&t=17370&p=75645&hilit=length#p75645
xnor
Postby xnor » Mon Nov 08, 2021 5:57 pm
xnor
Postby xnor » Wed Nov 10, 2021 3:35 am
since my problem files were FLAC.. I just disabled transcoding for them.. https://sourceforge.net/p/subsonic/bugs/175/#1015
xnor
