No Music shown after system update
Postby cba » Sun Feb 13, 2022 10:49 pm
Hello, I've been running across the internet and am out of ideas.
I recently upgraded my Linux Server to the latest Ubuntu LTS Release (20.04.3).
Since then, I am running into several issues:
-> I first was able to solve the 503 problem by switching over the java 8
-> I then needed to chown several directories to www-data (which runs my subsonic instance)
-> Also I needed to add the name of machine to /etc/hosts (again) for localhost
-> Now I can log in to subsonic, I see the playlists, but linkage to the music files seems to be lost. The music Library is completely empty.
-> All music is there, I chowned the directory (using -R) /home/username/Music to www-data. I checked that at least some files are r, all directories are rx in terms of rights. So www-data should be able to search these files.
-> I also tried to stop subsonic / move db directory / create blank db directory / copy old subsonic.script there start subsonic -> Scan.
/var/subsonic/subsonic.log shows:
[2022-02-13 13:40:00,659] INFO PlaylistService - Starting playlist import.
[2022-02-13 13:40:00,659] INFO PlaylistService - Completed playlist import.
[2022-02-13 13:47:33,639] INFO MediaScannerService - Starting to scan media library.
[2022-02-13 13:47:33,677] INFO MediaScannerService - Scanned media library with 1 entries.
[2022-02-13 13:47:33,677] INFO MediaScannerService - Marking non-present files.
[2022-02-13 13:47:33,680] INFO MediaScannerService - Marking non-present artists.
[2022-02-13 13:47:33,682] INFO MediaScannerService - Marking non-present albums.
[2022-02-13 13:47:33,686] INFO MediaScannerService - Completed media library scan.
[2022-02-13 13:47:33,889] INFO PlaylistService - Starting playlist import.
[2022-02-13 13:47:33,889] INFO PlaylistService - Completed playlist import.
No new files are added in /db - no music shown in subsonic
Is there anything, I could check? I am running out of ideas.
Option 1: Do you have any suggestions for further checks?
Options 2: I would be open to start from scratch on a clean install, but would like to keep my playlists - but am not sure how to backup/ save these.
Thanks for any pointers!
cba
cba
Re: No Music shown after system update
Postby bupkis » Sun Feb 20, 2022 10:30 am
I've got the same problem, FWIW but on Ubuntu 18.04.6.
I have no solution though. I suspect that this abandonware has finally been borked.
bupkis
Postby G8DHE » Sun Feb 20, 2022 12:26 pm
No real idea, but did it include a Java update ? Many have found that it needs an older version installed to continue to work, it seems you can have both installed if the posts relating to Java problems are correct!
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
