Mac getting HTTP ERROR: 503 SERVICE_UNAVAILABLE RequestURI=
Postby ScottyBeach » Tue Feb 22, 2022 7:11 pm
Hello Folks:
Subsonic has been running fine from a Mac for a couple years but recently stopped serving web pages.
Problem Description: SubSonic launches all right but any attempted connection back to it from remote (or local) browser returns error:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Troubleshooting Steps: I've tried downgrading from 6.1.6 back to 6.1.5. I've downgraded from. newer OpenJava back to a Java 8 version.
Playback Application and version: Web browsers: Tried Safari, Edge, Firefox, Chrome & Opera, various versions.
Subsonic Version: 6.1.6
Server Version: HSQL 1.8.0.5
Hardware Platform: server running on macOS 10.15.7, Catalina
Java Memory Limit: 29Mb memory used is listed in the SubSonic control panel window. Probably not the same thing.
Output from ffmpeg -i: result: "ffmpeg: command not found"
Last ten log file lines:
[2022-02-17 11:02:12,742] INFO HsqlDaoHelper - Checking database schema.
[2022-02-17 11:02:18,270] INFO HsqlDaoHelper - Done checking database schema.
[2022-02-17 11:02:18,353] INFO SettingsService - Java: 1.8.0_131, OS: Mac OS X
[2022-02-17 11:02:18,496] INFO PlayerDao - Deleted 6 player(s) that haven't been used after Sun Dec 19 11:02:18 EST 2021
[2022-02-17 11:02:18,553] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Fri Feb 18 02:00:00 EST 2022
[2022-02-17 11:02:18,609] INFO UPnPService - Starting UPnP service...
[2022-02-17 11:02:18,655] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Feb 17 11:07:18 EST 2022
[2022-02-17 11:02:18,770] INFO UPnPService - Disabling UPnP/DLNA media server
[2022-02-17 11:02:18,770] INFO UPnPService - Starting UPnP service - Done!
I would appreciate any advice. Thank you,
- Scott Beach
Toronto
ScottyBeach
Re: Mac getting HTTP ERROR: 503 SERVICE_UNAVAILABLE RequestU
Postby J_T_W » Tue Feb 22, 2022 7:59 pm
If you shut down the process, rename your db folder to something like db.bak, restart the service, wait for subsonic to rebuild the default database, can you then reach the page and log in with the default credentials?
J_T_W
Postby ScottyBeach » Tue Feb 22, 2022 8:05 pm
I'll try that now. Thanks.
ScottyBeach
Postby ScottyBeach » Tue Feb 22, 2022 8:30 pm
@J_T_W That worked all right. Thanks. So is it likely the DB that got corrupted? Is my best bet just to rebuild everything from scratch or can I move *some* files from the db.bak folder to the new one? I suppose I can just try and see.
Thanks for the suggestion and your help.
- Scott
ScottyBeach
Postby J_T_W » Wed Feb 23, 2022 6:22 pm
I have never had luck doing too much manipulation with the script file - long time back I just scripted nightly backups of the DB folder so when I do get the 503 error, I just back up a day or so until I'm back at a functional restore.
J_T_W
Users browsing this forum: No registered users and 81 guests
