"save as playlist" from starred songs gone?
Postby rumremix » Sat Mar 26, 2022 3:27 pm
I seem to have lost the feature to "save as playlist" for all my starred songs in the native subsonic web-based app. Did this feature disappear or is it because I now have too many starred tracks?
I've been starring tracks in subsonic for a long time and love to shuffle just starred tracks. But to make this starred list portable and available to shuffle, in AVSub for example, I need to first save the starred songs as a playlist. There used to be a convenient way to do this when navigating to the starred page (using tab at the top of the subsonic web view). I no longer see that option there now though. And I've been clicking all over trying to figure out how to do that again.
I may have created the starred song playlist before by first adding all starred songs to the play queue and then creating the playlist form the queue. But that feature has gone away as well. I can only add starred songs to the queue one at a time now -- not practical with over 6K songs -- making the starred song list much less useful. Something seems to have changed.
The last time I saved my starred tracks to a playlist using that method, the playlist that was created had 5709 songs. Since then, the number of songs I've starred in subsonic has risen to 6553. Is it possible that there is a limit to the number of starred songs that can be converted to a playlist or added to the queue, and once starred songs pass that limit, say maybe 6K, that feature goes away? Or has that feature disappeared for everyone with one of the upgrades, regardless of starred song count? I have playlists in subsonic with over 10K songs. So I know there is not a hard limit (in the 6K range at least) to simply creating a playlist.
Has anyone else experienced anything similar or have any suggestions for a remedy?
Thanks.
rumremix
Re: "save as playlist" from starred songs gone?
Postby rumremix » Mon Mar 28, 2022 10:18 pm
And in case it's helpful, here are more details:
Problem Description: No longer able to save starred songs list as a playlist. This feature was previously available to me.
Troubleshooting Steps: Clicked all around the subsonic web interface trying to find what used to be available.
Playback Application and version: I use the subsonic web app, Sonos and AVSub. But the lost feature I'm describing is in the subsonic web interface.
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server: jetty-6.1.x, java 1.8.0_152, HSQLDB, Windows 8 (110.4 MB / 145.0 MB)
Hardware Platform: Windows 8 box
Java Memory Limit: Not seeing that in the Subsonic control panel, but do see "Memory used: 105MB"
Problem Filename: n/a
Output from ffmpeg -i: n/a
Last ten log file lines:
[3/28/22 1:06:07 AM PDT]   INFO   MediaScannerService   Marking non-present albums.
[3/28/22 1:06:07 AM PDT]   INFO   MediaScannerService   Completed media library scan.
[3/28/22 1:06:08 AM PDT]   INFO   PlaylistService   Starting playlist import.
[3/28/22 1:06:08 AM PDT]   INFO   PlaylistService   Completed playlist import.
[3/28/22 1:23:20 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
[3/28/22 2:23:20 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
[3/28/22 3:23:20 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
[3/28/22 4:23:21 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
[3/28/22 5:23:21 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
[3/28/22 6:23:22 AM PDT]   INFO   NetworkService   Successfully forwarding port 2222.
rumremix
