can't change the port
Postby iedereenisgek » Fri May 29, 2009 5:32 pm
I'm trying to change the port of subsonic
on defauld it is on 80 if i type in 192.168.2.2 (my local Ip adres) it works
I want to change the port to 8000, i go to the subsonic control panel stop the service change the port to 8000 and restart the service.
I type in internet exploren 192.168.2.2:8000 but it doesn't work.
I have disactivated the windows firewall and i have no other firewall. I'm testing it al on a local PC.
I have Windows vista Ultimate and the version of subsonic is 3.7 beta 1 but it's the same with version 3.6
Best regards
iedereenisgek
Postby jonathanroz » Fri May 29, 2009 5:57 pm
When you right click on the subsonic service and choose to Open Subsonic in Browser does it work?
jonathanroz
Postby iedereenisgek » Fri May 29, 2009 6:01 pm
No that is not possible
He is trying to load http://localhost/ and that doesn't work
It only works with 192.168.2.2 (my IP adres)
iedereenisgek
Re: can't change the port
Postby mixmaster » Fri May 29, 2009 6:37 pm
iedereenisgek wrote: I'm testing it al on a local PC.
If you are testing it all on the local PC then localhost testing should be possible.
________
mixmaster
Postby iedereenisgek » Fri May 29, 2009 6:50 pm
I find it strange to
I have reinstalled it but it has no effect.
iedereenisgek
Postby iedereenisgek » Sun May 31, 2009 11:54 am
If i want to connect from an other PC to my PC where subsonic is installed, it doesn't work eather.
Best regards
iedereenisgek
