Can't Access Server Outside of my Home Network
Postby jonnydollaraz » Mon Jul 11, 2022 3:03 am
I am using the help template from the pinned post here so hopefully this will be enough information.
Problem Description: I just set up Subsonic on my computer today and it's working splendidly when I access the interface while on my local network. But as soon as I try to access it from my phone on the cellular network I get an error.
Troubleshooting Steps: I have checked the settings on the Network tab and made sure the box is ticked to allow auto config of the router. Status shows "Successfully forwarding port 4040. I have also ticked the box to access server over internet and added the subdomain name to the field. Status says "Successfully registered web address." I have also checked my Windows Firewall settings and it is set to allow Subsonic.
Playback Application and version: Have tried the Subsonic Android app and also had a friend attempt to access via browser with my unique address: http://porchlightfm.subsonic.org/
Subsonic Version: 6.1.6 (build 0cfa60) – November 10, 2019
Server Version: jetty-6.1.x, java 1.8.0_152, HSQLDB, Windows 10 (88.8 MB / 97.4 MB)
Hardware Platform: Server is running on Windows 10 Home v 21H2. The phone I'm using to try to connect is the Pixel 4a (5G) running Android 12
Java Memory Limit: 150MB
Problem Filename: N/A
Output from ffmpeg -i: I attempted to gather this from teh command prompt per the guide, but I got a message saying, "The syntax of the command is incorrect." Not sure what I did wrong. Sorry!
Last ten log file lines:
[7/10/22 7:06:30 PM MST]   INFO   UPnPService   Enabling UPnP/DLNA media server
[7/10/22 7:06:30 PM MST]   INFO   UPnPService   Starting UPnP service - Done!
[7/10/22 7:07:33 PM MST]   INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[7/10/22 7:07:36 PM MST]   INFO   VersionService   Resolved latest Subsonic final version to: 6.1.6
[7/10/22 7:07:36 PM MST]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
[7/10/22 7:08:48 PM MST]   INFO   NetworkService   Successfully forwarding port 4040.
[7/10/22 7:10:36 PM MST]   INFO   PlayerDao   Created player 4.
[7/10/22 7:10:36 PM MST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i H:\Powder River\Guns Of Powder River\01 Guns Of Powder River Part 1.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
[7/10/22 7:11:30 PM MST]   INFO   PodcastService   Starting scheduled Podcast refresh.
[7/10/22 7:11:30 PM MST]   INFO   PodcastService   Completed scheduled Podcast refresh.
[7/10/22 7:11:49 PM MST]   INFO   TranscodeInputStream   Starting transcoder: c:\subsonic\transcode\ffmpeg -i H:\Powder River\Season 05\01 The Twisted Badge Part 1.m4a -map 0:0 -b:a 320k -v 0 -f mp3 -
The error message I get in the Android app says "A network error occurred. Retrying 1 of 4." It then tries to connect 4 times and then give this error: "A network error occurred. Please check the server address or try again later."
Any ideas what could be the issue preventing access from outside my network?
-JD
jonnydollaraz
Re: Can't Access Server Outside of my Home Network
Postby d0tm4tr1x » Sat Sep 17, 2022 7:22 pm
What comes first to my mind
- did you use your external IP of hostname?
Yes,
- I would place your PC (IP) in the DMZ of your router, that opens all access to your PC.
- https://www.whatsmyip.org/port-scanner/ should show 4040
If above works, you know you'll have to tweak your router some more.
If it doesn't work, try turning of the security features on your PC, firewall, virusscanner (some have a firewall also)
If it works, tweak the security features
Don't forget to remove your PC from the DMZ and turn the security feature ON
Subsonic Premium
Ubuntu 20.04.4 LTS
d0tm4tr1x
