Cant install on root E:\
Postby jogilbu » Sat May 30, 2009 3:09 am
Hi. Been using subsonic a few years, but I had a harddrive-crash, and when I installed Win XP Pro 32 again, the drive went to E:
I cant change it, cause the windows is on that drive.
Getting problems when I install it. Cant open files under the install-setup. I have to Ignore to get to next step.
When the server is installed, (after skipping a lot), the I get an errormessage in the setupmeny, that says it cant open C:\XXXX\jetty
Is there no way to install it normal on E:?
jogilbu
Postby nublet » Sat Jul 11, 2009 10:33 pm
i ran install and i selected mine to install to D:\
yet it still put files on C:\ i do not know if this is related :?
i would like for it all to be on the D:\
which is where i keep most things so i can easily format and reinstall windows
i have also noticed that everything by default is set to C:\ be it playlists etc
be nice of the installer let u choose your Drive :cry:
nublet
